Resource Planning
In this example, you need to create a VPC, an ECS, a CCE cluster, and a VPC peering connection. For details about the resource planning, see Table 1.
The following resource planning details are only examples for your reference. You need to plan resources based on actual service requirements.
Resource | Description |
VPC | In this example, there are three VPCs, including the VPC where the ECS resides and the VPC where the testing cluster and production cluster reside. These VPCs are located in the same region, and the subnet CIDR blocks of these VPCs do not overlap.
ECS | In this example, there is one ECS located in vpc-X (with CIDR block of 192.168.0.0/16).
CCE cluster | In this example, there are two CCE clusters, including the testing and production clusters. The following lists some key parameter configurations. You can configure other parameters as required or use their default values.
VPC peering connection | In this example, there are two VPC peering connections. The network connection requirements are as follows:
