Pre-Binding Container Elastic Network Interfaces for CCE Turbo Clusters
In the Cloud Native 2.0 network model, each pod is allocated an elastic network interface or a supplementary network interface. The speed of elastic network interface creation and binding is slower than that of pod scaling, severely affecting the container startup speed in large-scale batch creation. Therefore, the Cloud Native Network 2.0 model provides the dynamic pre-binding of container elastic network interfaces to accelerate pod startup while improving IP resource utilization.
Notes and Constraints
- CCE Turbo clusters of 1.19.16-r4, 1.21.7-r0, 1.23.5-r0, 1.25.1-r0 or later support pre-binding of elastic network interfaces, global configuration at the cluster level, and custom settings at the node pool level. Custom settings of nodes out of a node pool is not supported.
- CCE Turbo clusters of 1.19.16-r2, 1.21.5-r0, 1.23.3-r0 to 1.19.16-r4, 1.21.7-r0, 1.23.5-r0 only support two parameters, nic-minimum-target and nic-warm-target, and do not support custom settings at the node pool level.
- Modify the dynamic pre-binding parameters using the console or API instead of the node annotations in the background. Otherwise, the modified annotations will be overwritten by the original values after the cluster is upgraded.
- CCE Turbo clusters of 1.19.16-r4, 1.21.7-r0, 1.23.5-r0, 1.25.1-r0, or earlier support high and low threshold for elastic network interface buffers. If users have enabled this feature, the original high and low threshold for elastic network interface pre-binding parameters is automatically converted to the dynamic pre-binding parameters of the container elastic network interfaces. If you want to modify the dynamic pre-binding parameters of the container elastic network interfaces on the console, change the original high and low threshold to 0:0 on the cluster configuration management console.
- If the node type of a CCE Turbo node pool is BMS and the cluster version is 1.19.16-r4, 1.21.7-r0, 1.23.5-r0, or any version earlier than 1.25.1-r0, the high and low thresholds for elastic network interface pre-binding (0.3:0.6 by default) are used by default. After the cluster is upgraded, the original high and low thresholds still take effect. You are advised to convert the high and low threshold parameters to the dynamic pre-binding parameters of container elastic network interfaces on the configuration management console of the node pool and delete the high and low threshold configuration to enable the latest dynamic pre-binding parameters.
- If the node type of a CCE Turbo node pool is not BMS and the cluster version is 1.19.16-r4, 1.21.7-r0, 1.23.5-r0, or any version earlier than 1.25.1-r0, the high and low thresholds for elastic network interface pre-binding (0.3:0.6 by default) are used by default. After the cluster is upgraded, the original high and low threshold still takes effect. If you want to enable the cluster-level global configuration, delete the annotation (node.yangtse.io/eni-warm-policy) of the node in the background.
How It Works
CCE Turbo provides four dynamic pre-binding parameters for container elastic network interfaces. You can properly configure the parameters based on your service requirements. (The node pool-level dynamic elastic network interface pre-binding parameters take priority over the cluster-level dynamic elastic network interface pre-binding parameters.)
Parameter |
Default Value |
Description |
Suggestion |
Minimum Number of Container ENIs Bound to a Node |
10 |
Minimum number of container elastic network interfaces bound to a node. The parameter value must be a positive integer. The value 10 indicates that there are at least 10 container elastic network interfaces bound to a node. If the number you entered exceeds the container elastic network interface quota of the node, the elastic network interface quota of the node will be used. |
Configure these parameters based on the number of pods. |
Upper Limit of Pre-bound Container ENIs |
0 |
If the number of elastic network interfaces bound to a node exceeds the value of nic-maximum-target, the system does not proactively pre-bind elastic network interfaces. If the value of this parameter is greater than or equal to the value of nic-minimum-target, the check on the maximum number of the pre-bound elastic network interfaces is enabled. Otherwise, the check is disabled. The parameter value must be a positive integer. The value 0 indicates that the check on the upper limit of pre-bound container elastic network interfaces is disabled. If the number you entered exceeds the container elastic network interface quota of the node, the elastic network interface quota of the node will be used. |
Container ENIs Dynamically Pre-bound to a Node |
2 |
Minimum number of pre-bound elastic network interfaces on a node. The value must be a number. When the value of nic-warm-target + the number of bound elastic network interfaces is greater than the value of nic-maximum-target, the system will pre-bind elastic network interfaces based on the difference between the value of nic-maximum-target and the number of bound elastic network interfaces. |
Set this parameter to the number of pods that can be scaled out instantaneously within 10 seconds. |
Threshold for Unbinding Pre-bound Container ENIs |
2 |
Only when the number of idle elastic network interfaces on a node minus the value of nic-warm-target is greater than the threshold, the pre-bound elastic network interfaces will be unbound and reclaimed. The value can only be a number.
Set this parameter based on the difference between the number of pods that are frequently scaled on most nodes within minutes and the number of pods that are instantly scaled out on most nodes within 10 seconds. |
Configuration Example
Level |
Service Scenario |
Configuration Example |
Cluster |
All nodes use the c7.4xlarge.2 model (supplementary network interface quota: 128). Most nodes run about 20 pods. Most nodes can run a maximum of 60 pods. Most nodes can scale out 10 pods within 10 seconds. Most nodes frequently scale in or out 15 pods within minutes. |
Cluster-level global configuration:
Node pool |
A node pool that uses the c7.8xlarge.2 high-specification model is created in the cluster. (supplementary network interface quota: 256) Most nodes run about 100 pods. Most nodes can run a maximum of 128 pods. Most nodes can scale out 10 pods within 10 seconds. Most nodes frequently scale in or out 12 pods within minutes. |
Custom settings at the node pool level:
Pods using HostNetwork are excluded.
Cluster-level Global Configuration
- Log in to the CCE console. In the navigation pane, choose Clusters.
- Click
next to the target cluster and choose Manage.
Figure 1 Managing a cluster - In the window that slides out from the right, click Networking Components. For details about the parameter configurations, see Configuration Example.
- After the configuration is complete, click OK. Wait for about 10 seconds for the configuration to take effect.
Custom Settings at the Node Pool Level
- Click the cluster name to access the cluster console, choose Nodes in the navigation pane, and click the Node Pools tab.
- Locate the row containing the target node pool and click Manage.
- In the window that slides out from the right, click Networking Components and enable node pool container elastic network interface pre-binding. For details about the parameter configurations, see Configuration Example.
