Help Center/ Cloud Container Engine/ Best Practices/ Security/ Using Identity Authentication Securely in a CCE Cluster
Updated on 2026-11-16 GMT+08:00
Using Workload Identity Authentication to Access Cloud Services
With workload identity authentication, the workloads in a cluster are allowed to impersonate IAM users to access cloud services, and information such as the AK/SK of the account is not required, reducing security risks.
For details, see the following sections:
Ensuring Least Privilege for IAM Accounts
On the IAM console, select a user group, view the authorization records, and select only necessary actions based on service permissions. Do not select high-risk permissions such as XXX FullAccess and XXX Administrator unless necessary.
Enabling a Custom Agency for Add-ons and Disabling Statically Stored Temporary Credentials in a Cluster
Supported minimum cluster versions: v1.28.15-r92, v1.29.15-r52, v1.30.14-r52, v1.31.14-r12, v1.32.9-r12, v1.33.7-r12, and v1.34.3-r2
Based on the principle of least privilege (PoLP), an IAM user must have at least the following IAM operation permissions:
  • iam:agencies:createAgency: creates an agency.
  • iam:permissions:revokeRoleFromAgencyOnProject: removes permissions of an agency for a region-specific project.
  • iam:permissions:grantRoleToAgencyOnProject: grants permissions to an agency for a region-specific project.
  • iam:permissions:grantRoleToAgency: grants permissions to an agency.
  • iam:roles:createRole: creates a custom policy.
  • iam:roles:updateRole: modifies a custom policy.
  • If a cluster uses a custom agency, you can clear the agency permissions that are not required by the cluster to minimize authorization. For details, see Custom Agencies for Clusters.
  • If an add-on uses a custom agency, you can clear the agency permissions that are not required by the add-on. For details, see Custom Agencies for Add-ons.
  • Disable the temporary credentials stored statically in the cluster. For details, see Disabling a Statically Stored Temporary Credential in a Cluster.
  • Narrow the imagePullSecret permissions: Use a node agency to narrow the permissions to upload images to and download images from SWR. For details about node agencies, see System Agencies.
  • Enable cluster audit log collection and report logs to LTS. Enable Kubernetes audit log collection in Logging. For details, see Collecting Audit Logs.
