Interconnecting GitLab with SWR and CCE for CI/CD
Background
GitLab is an open-source version management system developed with Ruby on Rails for Git project repository management. It supports web-based access to public and private projects. Similar to GitHub, GitLab allows you to browse source code, manage bugs and comments, and control team member access to repositories. You will find it very easy to view committed versions and file history database. Team members can communicate with each other using the built-in chat program (Wall).
GitLab provides powerful CI/CD functions and is widely used in software development.
This section describes how to interconnect GitLab with SWR and CCE for CI/CD.
Preparations
- Create a CCE cluster and a node and bind an EIP to the node for downloading an image during GitLab Runner installation.
- Download and configure kubectl to connect to the cluster.
Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Overview, locate the Connection Information area, click Configure next to kubectl, and configure kubectl as instructed.
- Install Helm 3.
Installing GitLab Runner
Log in to GitLab, choose Settings > CI/CD in the project view, click Expand next to Runners, and search for the GitLab Runner registration URL and token.
Create the values.yaml file and fill in the following information:
# Registration URL
gitlabUrl: https://gitlab.com/
# Registration token
runnerRegistrationToken: "******"
rbac:
create: true
runners:
privileged: true Create a GitLab namespace.
kubectl create namespace gitlab
Install GitLab Runner using Helm.
helm repo add gitlab https://charts.gitlab.io helm install --namespace gitlab gitlab-runner -f values.yaml gitlab/gitlab-runner --version=0.43.1
After the installation, you can obtain the gitlab-runner workload on the CCE console and view the connection information in GitLab later.
Creating an Application
Place the application to be created in the GitLab project repository. This section takes Nginx modification as an example. For details, visit https://gitlab.com/c8147/cidemo/-/tree/main.
The following files are included:
- .gitlab-ci.yml: GitLab CI file, which will be described in detail in Creating a Pipeline.
- Dockerfile: used to build Docker images.
- index.html: used to replace the index page of Nginx.
- k8s.yaml: used to deploy the Nginx app. A Deployment named nginx-test and a Service named nginx-test will be created.
The preceding files are only examples. You can replace or modify them accordingly.
Configuring Global Variables
When using pipelines, build an image, upload it to SWR, and run kubectl commands to deploy the image in the cluster. Before performing these operations, you must log in to SWR and obtain the credential for connecting to the cluster. You can define the information as variables in GitLab.
Log in to GitLab, choose Settings > CI/CD in the project view, and click Expand next to Variables to add variables.
- kube_config
kubeconfig.json file used for kubectl command authentication. Run the following command on the host where kubectl is configured to convert the file to the Base64 format:
echo $(cat ~/.kube/config | base64) | tr -d " "
The command output is the content of kubeconfig.json.
- project: project name.
Log in to the management console, hover the cursor on your username in the upper right corner, and choose My Credentials. In the Projects area on the API Credentials page, check the name of the project in your current region.
- swr_ak: access key.
Log in to the management console, hover the cursor on your username in the upper right corner, and choose My Credentials. In the navigation pane, choose Access Keys. Click Create Access Key, enter the description, and click OK. In the displayed Information dialog box, click Download. After the certificate is downloaded, obtain the AK and SK information from the credentials file.
- swr_sk: secret key for logging in to SWR.
Run the following command to obtain the key pair. Replace $AK and $SK with the AK and SK obtained in the preceding steps.
printf "$AK" | openssl dgst -binary -sha256 -hmac "$SK" | od -An -vtx1 | sed 's/[ \n]//g' | sed 'N;s/\n//'
The command output displays the login key pair.
Creating a Pipeline
Log in to GitLab and add the .gitlab-ci.yml file to Repository.
The content is as follows:
# Define pipeline stages, including package, build, and deploy.
stages:
- package
- build
- deploy
# If no image is specified in each stage, the default image docker:latest is used.
image: swr.ap-southeast-3.myhuaweicloud.com/container/docker:latest
# In the package stage, only printing is performed.
package:
stage: package
script:
- echo "package"
# In the build stage, the Docker-in-Docker mode is used.
build:
stage: build
# Define environment variables for the build stage.
variables:
DOCKER_HOST: tcp://docker:2375
# Define the image for running Docker-in-Docker.
services:
- docker:18.09-dind
script:
- echo "build"
# Log in to SWR.
- docker login -u $project@$swr_ak -p $swr_sk swr.ap-southeast-3.myhuaweicloud.com
# Build an image. k8s-dev is the organization name in SWR. Replace it to the actual name.
- docker build -t swr.ap-southeast-3.myhuaweicloud.com/k8s-dev/nginx:$CI_PIPELINE_ID .
# Push the image to SWR.
- docker push swr.ap-southeast-3.myhuaweicloud.com/k8s-dev/nginx:$CI_PIPELINE_ID
deploy:
# Use the kubectl image.
image:
entrypoint: [""]
stage: deploy
script:
# Configure the kubeconfig file.
- mkdir -p $HOME/.kube
- export KUBECONFIG=$HOME/.kube/config
- echo $kube_config |base64 -d > $KUBECONFIG
# Replace the image in the k8s.yaml file.
- sed -i "s/<IMAGE_NAME>/swr.ap-southeast-3.myhuaweicloud.com\/k8s-dev\/nginx:$CI_PIPELINE_ID/g" k8s.yaml
- cat k8s.yaml
# Deploy an application.
- kubectl apply -f k8s.yaml After the .gitlab-ci.yml file is saved, the pipeline is started immediately. You can view the pipeline execution status in GitLab.
Verifying Deployment
After the pipeline is deployed, locate the nginx-test Service on the CCE console, query its access address, and run the curl command to access the Service.
# curl xxx.xxx.xxx.xxx:31111 Hello Gitlab!
If the preceding information is displayed, the deployment is correct.
Common Issues
- If the following problem occurs during the deployment:
Or
Check whether the following commands are missing in the .gitlab-ci.yml file. If yes, add them to the .gitlab-ci.yml file.
... script: # Configure the kubeconfig file. - mkdir -p $HOME/.kube - export KUBECONFIG=$HOME/.kube/config - echo $kube_config |base64 -d > $KUBECONFIG # Replace the image in the k8s.yaml file. ... - If Docker cannot be executed, information similar to the following will display.
The privileged: true parameter fails to be transferred during GitLab Runner installation. As a result, you do not have the permissions to run the Docker command. To resolve this issue, find GitLab Runner in the workload list on the CCE console, add the environment variable KUBERNETES_PRIVILEGED, and set its value to true.
