Using Nodes Securely in a CCE Cluster
Handling Vulnerabilities Released on the Official Website Promptly
Before a new node image is released, you can fix the node vulnerabilities by referring to Vulnerability Fixing Policies.
Preventing Nodes from Being Exposed to the Internet
- Do not bind an EIP to a node to reduce the attack surface unless necessary.
- If an EIP must be used, properly configure the firewall or security group rules to restrict access of unnecessary ports and IP addresses.
You may have configured the kubeconfig.json file on a node in your cluster. kubectl can use the certificate and private key in this file to control the entire cluster. You are advised to delete unnecessary files from the /root/.kube directory on the node to prevent malicious use.
rm -rf /root/.kube
Hardening VPC Security Group Rules
CCE is a universal container platform. Its default security group rules apply to general scenarios. You can harden the security group rules set for CCE clusters based on security requirements on the Security Groups page of Network Console.
For details, see How Can I Configure a Security Group Rule for a Cluster?
Hardening Node Security on Demand
CCE cluster nodes use the default settings of open-source OSs. After a node is created, you need to perform security hardening according to your service requirements.
You can use either of the following ways to harden node security on CCE:
- Use the post-installation script after the node is created. For details, see the description about Post-installation Script in Advanced Settings during node creation. This script is user-defined.
- Build custom images to create worker nodes. For details about the creation process, see Creating a Custom CCE Node Image.
Forbidding Containers to Obtain the Node Metadata
If multiple users deploy containers in the same CCE cluster, ensure that the containers cannot access the OpenStack management address (169.254.169.254) to prevent them from obtaining the node metadata.
For details about how to restore the metadata, see the "Notes" section in Obtaining ECS Details Using Metadata.
This restoration may affect the password change on the ECS console. Therefore, you must verify the function before the restoration.
- Obtain the network model and container CIDR of the cluster.
On the Clusters page of the CCE console, view the network model and container CIDR of the cluster.
- Prevent the container from obtaining the node metadata.
- In a cluster using a VPC network
- Log in to each node in the cluster as user root and run the following command:
iptables -I OUTPUT -s {container_cidr} -d 169.254.169.254 -j REJECT{container_cidr} indicates the container CIDR block of the cluster, for example, 10.0.0.0/16.
To ensure configuration persistence, write the command to the /etc/rc.local script.
- Run the following commands in the container to access the userdata and metadata interfaces of OpenStack and check whether the request is intercepted:
curl 169.254.169.254/openstack/latest/meta_data.json curl 169.254.169.254/openstack/latest/user_data
- In a cluster using a container tunnel network
iptables -I FORWARD -s {container_cidr} -d 169.254.169.254 -j REJECT{container_cidr} indicates the container CIDR block of the cluster, for example, 10.0.0.0/16.
- In a CCE Turbo cluster
No additional configuration is required for a cluster of a version earlier than v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, or v1.28.3-r0.
For a cluster of v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or a later version, log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Settings, click the Network tab, and view the value of Pod Access to Metadata.- If Pod Access to Metadata is not enabled, no additional configuration is required. The container cannot obtain the node metadata.
- If Pod Access to Metadata is enabled, take the following steps to prevent the container from obtaining the node metadata:
