Updated on 2026-01-05 GMT+08:00
Solution Overview
Application Scenarios
Containers are growing in popularity and Kubernetes simplifies containerized deployment. Many companies choose to build their own Kubernetes clusters. However, the O&M workload of on-premises clusters is heavy, and O&M personnel need to configure the management systems and monitoring solutions by themselves. This increases the labor costs while decreasing the efficiency.
In terms of performance, an on-premises cluster has poor scalability due to its fixed specifications. Auto scaling cannot be implemented in case of traffic surges, which may easily result in the insufficient or waste of cluster resources. In addition, disaster recovery risks are not considered for deploying an on-premises cluster, leading to poor reliability. Once a fault occurs, the entire cluster may fail, resulting in serious production incidents.
Now you can address the preceding challenges by using CCE, a service that allows easy cluster management and flexible scaling. CCE is integrated with application service meshes and Helm charts to simplify cluster O&M and reduce operations costs. It is easy to use and delivers high performance, security, reliability, openness, and compatibility. This section describes the solution and procedure for migrating on-premises clusters to CCE.
Precautions
Compared with on-premises Kubernetes clusters, CCE clusters have multiple advantages. For details, see Product Advantages. There are some restrictions when using CCE clusters. For details, see Notes and Constraints. Evaluate the restrictions before using CCE clusters.
Migration Solution
This section describes a cluster migration solution, which applies to the following types of clusters:
  • Kubernetes clusters built in local IDCs
  • On-premises clusters built using multiple ECSs
  • Clusters provided by other cloud service providers
  • CCE clusters that are no longer maintained and cannot be upgraded in place
Before the migration, analyze all resources in the source clusters and then determine the migration solution. Resources that can be migrated include resources inside and outside the clusters, as listed in the table below.
Table 1 Resources that can be migrated
Category
Migration Object
Remarks
Resources inside a cluster
All objects in a cluster, including pods, jobs, Services, Deployments, and ConfigMaps.
You are not advised to migrate the resources in the velero and kube-system namespaces.
  • velero: Resources in this namespace are created by the migration tool and do not need to be migrated.
  • kube-system: Resources in this namespace are system resources. If this namespace of the source cluster contains resources created by users, migrate the resources on demand.
CAUTION:
If you are migrating or backing up cluster resources in CCE, for example, from a namespace to another, do not back up the paas.elb secret. It is because paas.elb is periodically updated. After the backup, the secret may become invalid when it is restored. This may affect the network storage functions.
PersistentVolumes (PVs) mounted to containers
Due to restrictions of the restic tool, migration is not supported for the hostPath storage volume. For details about how to solve the problem, see hostPath Volumes Cannot Be Backed Up.
Resources outside a cluster
On-premises image repositories
Resources can be migrated to SWR.
Non-containerized databases
Resources can be migrated to Relational Database Service (RDS).
Non-local storage, such as object storage
Resources can be migrated to Object Storage Service (OBS).
Figure 1 shows the migration process. You can migrate resources outside a cluster as required.
Figure 1 Migration solution diagram
Migration Process
The cluster migration process is as follows:
  1. Plan resources for the target cluster.
    For details about the differences between CCE clusters and on-premises clusters, see Key Performance Parameter in Resource Planning for the Target Cluster. Plan resources as required and ensure that the performance configuration of the target cluster is the same as that of the source cluster.
  2. Migrate resources outside a cluster.
    To migrate resources outside the cluster, see Migrating Resources Outside a Cluster.
  3. Install the migration tool.
    After resources outside a cluster are migrated, you can use a migration tool to back up and restore application configurations in the source and target clusters. For details about how to install the tool, see Installing the Migration Tool.
  4. Migrate resources in the cluster.
    Use Velero to back up resources in the source cluster to OBS and restore the resources to the target cluster. For details, see Migrating Resources in a Cluster (Velero).
    • Backing Up an Application in the Source Cluster
      To back up resources, use Velero to create a backup object in the source cluster, obtain and back up cluster data and resources, package the data, and upload the package to the object storage that is compatible with the S3 protocol. Cluster resources will be stored in the JSON format.
    • Restoring the Application to the Target Cluster
      During restoration in the target cluster, Velero specifies the temporary object bucket that stores the backed up data, downloads the backed up data to the new cluster, and redeploys resources based on the JSON file.
  5. Update and adapt resources.
    After the migration, cluster resources may fail to be deployed. Update and adapt the faulty resources. The possible adaptation problems are as follows:
  6. Perform additional tasks.
    After cluster resources are properly deployed, verify application functions and switch service traffic to the target cluster. After confirming that all services are running properly, bring the source cluster offline.
