Using Spark
Updated on 2024-12-28 GMT+08:00
You can use Spark's Kubernetes scheduler spark-submit to submit Spark applications to Kubernetes clusters. For details, see Running Spark on Kubernetes. The submission mechanism works as follows:
  • Create a pod to run the Spark driver.
  • The driver creates pods for executing the programs and establishes a connection with these pods.
  • After the application is complete, the pods that execute the programs are terminated and cleaned up, but the driver pod exists and remains in the completed state until the garbage is collected or it is manually cleaned up. In the completed state, the driver pod does not use any computing or memory resources.
Figure 1 Submission mechanism
Running SparkPi on CCE
  1. Install kubectl on the node where Spark is running. For details, see Connecting to a Cluster Using kubectl.
  2. Run the following command to grant the cluster-level permissions:
    # Create a service account.
    kubectl create serviceaccount spark
    # Bind the ClusterRole spark-role to the service account created in the previous step, specify the default namespace, and grant the ClusterRole permission to edit resources.
    kubectl create clusterrolebinding spark-role --clusterrole=edit --serviceaccount=default:spark --namespace=default
  3. Submit a SparkPi job to CCE. The following shows an example:
    spark-submit \
      --master k8s://https://**.**.**.**:5443 \
      --deploy-mode cluster \
      --name spark-pi \
      --class org.apache.spark.examples.SparkPi \
      --conf spark.executor.instances=2 \
      --conf spark.kubernetes.authenticate.driver.serviceAccountName=spark \
      --conf spark.kubernetes.container.image=swr.ap-southeast-1.myhuaweicloud.com/dev-container/spark:3.1.3-obs \
      local:///root/spark-obs/examples/jars/spark-examples_2.12-3.1.1.jar
    Parameters:
    • --master: indicates the API Server of the cluster. https://**.**.**.**:5443 is the address of the master node used in ~/.kube/config. It can be obtained from kubectl cluster-info.
    • --deploy-mode:
      • cluster: a mode in which the driver is deployed on the worker nodes.
      • client: (default value) a mode in which the driver is deployed locally as an external client.
    • --name: indicates the name of a job. It is used to name the pods in the cluster.
    • --class: indicates the applications, for example, org.apache.spark.examples.SparkPi.
    • --conf: indicates the Spark's configuration parameters. It is in the key-value pair format. All parameters that can be specified using --conf are read from the ~/spark-obs/conf/spark-defaults.conf file by default. Therefore, the general configuration can be written to be the default settings, the same way as Interconnecting Spark with OBS.
      • spark.executor.instances: indicates the number of pods for executing programs.
      • spark.kubernetes.authenticate.driver.serviceAccountName: indicates the driver's cluster-level permissions. Select the service account created in 2.
      • spark.kubernetes.container.image: indicates the image path of the image pushed to SWR in Pushing an Image to SWR.
    • local: indicates the path to the JAR packages stored in the local files. In this example, a local file is used to store the JAR packages. The value of this parameter can be file, http, or local. For details, see the Official Documentation.
Accessing OBS
Use spark-submit to deliver an HDFS job. Change the value of obs://bucket-name/filename at the end of the script to the actual file name of the tenant.
spark-submit \
  --name spark-hdfs-test \
  --class org.apache.spark.examples.HdfsTest \
  local:///root/spark-obs/examples/jars/spark-examples_2.12-3.1.1.jar obs://bucket-name/filename
Support for Spark Shell Commands to Interact with Spark-Scala
spark-shell \
Run the following commands to define the algorithms of Spark computing jobs linecount and wordcount:
def linecount(input:org.apache.spark.sql.Dataset[String]):Long=input.filter(line => line.length()>0).count()
def wordcount(input:org.apache.spark.sql.Dataset[String]):Long=input.flatMap(value => value.split("\\s+")).groupByKey(value => value).count().count()
Run the following commands to define data sources:
var alluxio = spark.read.textFile("alluxio://alluxio-master:19998/sample-1g")
var obs = spark.read.textFile("obs://gene-container-gtest/sample-1g")
var hdfs = spark.read.textFile("hdfs://192.168.1.184:9000/user/hadoop/books/sample-1g")
Run the following command to start computing jobs:
spark.time(wordcount(obs))
spark.time(linecount(obs))
