Deploying and Using TensorFlow in a CCE Cluster
Preparing Resources
- Create a CCE cluster and GPU nodes, and use the CCE AI Suite (NVIDIA GPU) add-on to install the graphics card driver.
- Add an object storage volume to the cluster.
Pre-configuring Data
Download data from https://github.com/zalandoresearch/fashion-mnist.
Obtain the TensorFlow machine learning example and modify it based on your requirements.
basicClass.py
# TensorFlow and tf.keras
import tensorflow as tf
from tensorflow import keras
# Helper libraries
import numpy as np
import gzip
from tensorflow.python.keras.utils import get_file
import matplotlib as mpl
mpl.use('Agg')
print(tf.__version__)
#fashion_mnist = keras.datasets.fashion_mnist
#(train_images, train_labels), (test_images, test_labels) = fashion_mnist.load_data()
def load_data():
base = "file:////home/data/"
files = [
'train-labels-idx1-ubyte.gz', 'train-images-idx3-ubyte.gz',
't10k-labels-idx1-ubyte.gz', 't10k-images-idx3-ubyte.gz'
paths = []
for fname in files:
paths.append(get_file(fname, origin=base + fname))
with gzip.open(paths[0], 'rb') as lbpath:
y_train = np.frombuffer(lbpath.read(), np.uint8, offset=8)
with gzip.open(paths[1], 'rb') as imgpath:
x_train = np.frombuffer(
imgpath.read(), np.uint8, offset=16).reshape(len(y_train), 28, 28)
with gzip.open(paths[2], 'rb') as lbpath:
y_test = np.frombuffer(lbpath.read(), np.uint8, offset=8)
with gzip.open(paths[3], 'rb') as imgpath:
x_test = np.frombuffer(
imgpath.read(), np.uint8, offset=16).reshape(len(y_test), 28, 28)
return (x_train, y_train), (x_test, y_test)
(train_images, train_labels), (test_images, test_labels) = load_data()
class_names = ['T-shirt/top', 'Trouser', 'Pullover', 'Dress', 'Coat',
'Sandal', 'Shirt', 'Sneaker', 'Bag', 'Ankle boot']
plt.figure()
plt.imshow(train_images[0])
plt.colorbar()
plt.grid(False)
plt.savefig('/home/img/basicimg1.png')
train_images = train_images / 255.0
test_images = test_images / 255.0
plt.figure(figsize=(10,10))
for i in range(25):
plt.subplot(5,5,i+1)
plt.xticks([])
plt.yticks([])
plt.grid(False)
plt.imshow(train_images[i], cmap=plt.cm.binary)
plt.xlabel(class_names[train_labels[i]])
plt.savefig('/home/img/basicimg2.png')
model = keras.Sequential([
keras.layers.Flatten(input_shape=(28, 28)),
keras.layers.Dense(128, activation=tf.nn.relu),
keras.layers.Dense(10, activation=tf.nn.softmax)
model.compile(optimizer=tf.train.AdamOptimizer(),
loss='sparse_categorical_crossentropy',
metrics=['accuracy'])
model.fit(train_images, train_labels, epochs=5)
test_loss, test_acc = model.evaluate(test_images, test_labels)
print('Test accuracy:', test_acc)
predictions = model.predict(test_images)
def plot_image(i, predictions_array, true_label, img):
predictions_array, true_label, img = predictions_array[i], true_label[i], img[i]
plt.grid(False)
plt.xticks([])
plt.yticks([])
plt.imshow(img, cmap=plt.cm.binary)
predicted_label = np.argmax(predictions_array)
if predicted_label == true_label:
color = 'blue'
else:
color = 'red'
plt.xlabel("{} {:2.0f}% ({})".format(class_names[predicted_label],
100*np.max(predictions_array),
class_names[true_label]),
color=color)
def plot_value_array(i, predictions_array, true_label):
predictions_array, true_label = predictions_array[i], true_label[i]
plt.grid(False)
plt.xticks([])
plt.yticks([])
thisplot = plt.bar(range(10), predictions_array, color="#777777")
plt.ylim([0, 1])
thisplot[predicted_label].set_color('red')
thisplot[true_label].set_color('blue')
i = 0
plt.figure(figsize=(6,3))
plt.subplot(1,2,1)
plot_image(i, predictions, test_labels, test_images)
plt.subplot(1,2,2)
plot_value_array(i, predictions, test_labels)
plt.savefig('/home/img/basicimg3.png')
i = 12
plt.subplot(1,2,1)
plt.subplot(1,2,2)
plt.savefig('/home/img/basicimg4.png')
# Plot the first X test images, their predicted label, and the true label
# Color correct predictions in blue, incorrect predictions in red
num_rows = 5
num_cols = 3
num_images = num_rows*num_cols
plt.figure(figsize=(2*2*num_cols, 2*num_rows))
for i in range(num_images):
plt.subplot(num_rows, 2*num_cols, 2*i+1)
plt.subplot(num_rows, 2*num_cols, 2*i+2)
plt.savefig('/home/img/basicimg5.png')
Go to the OBS bucket, create the data and img folders, and upload basicClass.py.
Go to the data folder and upload the four .gz files downloaded from GitHub.
ML Example
In this section, the ML example from the TensorFlow official website is used. For details, see https://www.tensorflow.org/tutorials/keras/classification?hl=en-us.
Create a job using the third-party tensorflow/tensorflow:1.15.5-gpu and configure the container specifications.
Add pip install matplotlib;python /home/basicClass.py in the Start Command area.
Mount the created OBS volume.
Click Create. Wait until the job execution is complete. On the OBS page, you can view the execution results that are shown as pictures.
If you want to use kubectl, you can use the following example YAML:
kind: Job
apiVersion: batch/v1
namespace: default
parallelism: 1
completions: 1
backoffLimit: 6
template:
volumes:
- name: cce-obs-tensorflow
persistentVolumeClaim:
claimName: cce-obs-tensorflow
containers:
- name: container-0
image: 'tensorflow/tensorflow:1.15.5-gpu'
restartPolicy: OnFailure
command:
- /bin/bash
args:
- '-c'
- pip install matplotlib;python /home/basicClass.py
resources:
limits:
cpu: '2'
memory: 4Gi
nvidia.com/gpu: '1'
requests:
cpu: '2'
memory: 4Gi
nvidia.com/gpu: '1'
volumeMounts:
mountPath: /home
imagePullPolicy: IfNotPresent
imagePullSecrets:
- name: default-secret
