Updated on 2026-03-10 GMT+08:00
Training a TensorFlow Model
After Kubeflow is deployed, it is easy to use the parameter servers and workers to train TensorFlow models. This section describes an official TensorFlow training example provided by Kubeflow. For details, see TensorFlow Training (TFJob).
Running a Mnist Example
  1. Deploy a TFJob to start training.
    Create a tf-mnist.yaml file. The following is an example:
    apiVersion: "kubeflow.org/v1"
    kind: TFJob
      namespace: kubeflow
      tfReplicaSpecs:
        Worker:
          replicas: 2
          restartPolicy: OnFailure
          template:
              containers:
                - name: tensorflow
                  image: kubeflow/tf-mnist-with-summaries:latest
                  command:
                    - "python"
                    - "/var/tf_mnist/mnist_with_summaries.py"
  2. Create the TFJob.
    kubectl apply -f tf-mnist.yaml
  3. View the logs after the worker running was complete.
    kubectl -n kubeflow logs tfjob-simple-worker-0
    Information similar to the following is displayed:
    Accuracy at step 900: 0.964
    Accuracy at step 910: 0.9653
    Accuracy at step 920: 0.9665
    Accuracy at step 930: 0.9681
    Accuracy at step 940: 0.9664
    Accuracy at step 950: 0.9667
    Accuracy at step 960: 0.9694
    Accuracy at step 970: 0.9683
    Accuracy at step 980: 0.9687
    Accuracy at step 990: 0.966
    Adding run metadata for 999
  4. Delete the TFJob.
    kubectl delete -f tf-mnist.yaml
Using a GPU
The training can be performed in a GPU. In this scenario, the cluster must contain GPU nodes, and proper drivers must be installed.
  1. Specify the GPU in the TFJob.
    Create a tf-gpu.yaml file. The following is an example:
    This example runs in the TensorFlow distributed architecture. The ResNet50 model in the convolutional neural network (CNN) is used to train randomly generated images. A total of 32 (batch_size) images are trained each time, and the images are trained 100 times in total. Additionally, the performance (image/sec) of each training is recorded.
    kind: "TFJob"
      tfReplicaSpecs:
        PS:
          replicas: 1
          template:
              creationTimestamp: null
              containers:
                - args:
                    - python
                    - tf_cnn_benchmarks.py
                    - --batch_size=32
                    - --model=resnet50
                    - --variable_update=parameter_server
                    - --flush_stdout=true
                    - --num_gpus=1
                    - --local_parameter_device=cpu
                    - --device=cpu
                    - --data_format=NHWC
                  image: docker.io/kubeflow/tf-benchmarks-cpu:v20171202-bdab599-dirty-284af3
                  ports:
                    - containerPort: 2222
                  resources:
                    limits:
                      cpu: "1"
                  workingDir: /opt/tf-benchmarks/scripts/tf_cnn_benchmarks
        Worker:
          replicas: 1
          template:
              containers:
                - args:
                    - python
                    - --batch_size=32
                    - --model=resnet50
                    - --num_gpus=1
                    - --device=gpu
                  image: docker.io/kubeflow/tf-benchmarks-gpu:v20171202-bdab599-dirty-284af3
                  ports:
                  resources:
                    limits:
                      nvidia.com/gpu: 1       # Number of GPUs
    kubectl apply -f tf-gpu.yaml
  3. After the worker runs the job (about 5 minutes if a GPU is used), view the result.
    kubectl logs tf-smoke-gpu-worker-0
    INFO|2023-09-02T12:04:25|/opt/launcher.py|27| Running warm up
    INFO|2023-09-02T12:08:55|/opt/launcher.py|27| Done warm up
    INFO|2023-09-02T12:08:55|/opt/launcher.py|27| Step      Img/sec loss
    INFO|2023-09-02T12:08:56|/opt/launcher.py|27| 1 images/sec: 68.8 +/- 0.0 (jitter = 0.0) 8.777
    INFO|2023-09-02T12:09:00|/opt/launcher.py|27| 10        images/sec: 70.4 +/- 0.4 (jitter = 1.8) 8.557
    INFO|2023-09-02T12:09:04|/opt/launcher.py|27| 20        images/sec: 70.5 +/- 0.3 (jitter = 1.5) 8.090
    INFO|2023-09-02T12:09:09|/opt/launcher.py|27| 30        images/sec: 70.3 +/- 0.3 (jitter = 1.6) 8.041
    INFO|2023-09-02T12:09:13|/opt/launcher.py|27| 40        images/sec: 70.1 +/- 0.2 (jitter = 1.7) 9.464
    INFO|2023-09-02T12:09:18|/opt/launcher.py|27| 50        images/sec: 70.1 +/- 0.2 (jitter = 1.6) 7.797
    INFO|2023-09-02T12:09:23|/opt/launcher.py|27| 60        images/sec: 70.1 +/- 0.2 (jitter = 1.6) 8.595
    INFO|2023-09-02T12:09:27|/opt/launcher.py|27| 70        images/sec: 70.0 +/- 0.2 (jitter = 1.7) 7.853
    INFO|2023-09-02T12:09:32|/opt/launcher.py|27| 80        images/sec: 69.9 +/- 0.2 (jitter = 1.7) 7.849
    INFO|2023-09-02T12:09:36|/opt/launcher.py|27| 90        images/sec: 69.8 +/- 0.2 (jitter = 1.7) 7.911
    INFO|2023-09-02T12:09:41|/opt/launcher.py|27| 100       images/sec: 69.7 +/- 0.1 (jitter = 1.7) 7.853
    INFO|2023-09-02T12:09:41|/opt/launcher.py|27| ----------------------------------------------------------------
    INFO|2023-09-02T12:09:41|/opt/launcher.py|27| total images/sec: 69.68
    INFO|2023-09-02T12:09:42|/opt/launcher.py|80| Finished: python tf_cnn_benchmarks.py --batch_size=32 --model=resnet50 --variable_update=parameter_server --flush_stdout=true --num_gpus=1 --local_parameter_device=cpu --device=gpu --data_format=NHWC --job_name=worker --ps_hosts=tf-smoke-gpu-ps-0.default.svc:2222 --worker_hosts=tf-smoke-gpu-worker-0.default.svc:2222 --task_index=0
    INFO|2023-09-02T12:09:42|/opt/launcher.py|84| Command ran successfully sleep for ever.
    The training performance of a single GPU is 69.68 images per second.
