Deploying Kubeflow
Updated on 2024-12-28 GMT+08:00
Background
Building an end-to-end AI computing platform based on Kubernetes is complex. More than a dozen of phases is required. Apart from the familiar model training phase, the process also includes data collection, preprocessing, resource management, feature extraction, data verification, model management, model release, and monitoring. If AI algorithm engineers want to run a model training task, they have to build an entire AI computing platform first. Imagine how time- and labor-consuming that is and how much knowledge and experience it requires.
Figure 1 Phrases for training a model
Kubeflow was released in 2017, which is built on containers and Kubernetes. It aims to provide data scientists, machine learning engineers, and system O&M personnel with a platform for agile deployment, development, training, release, and management of machine learning services. It leverages the advantages of cloud native technologies to enable users to quickly and easily deploy, use, and manage the most popular machine learning software.
Kubeflow 1.0 is now available, providing capabilities in development, building, training, and deployment that cover the entire process of machine learning and deep learning for enterprise users.
The following shows an example.
With Kubeflow 1.0, you first develop a model using Jupyter, and then set up containers using tools such as Fairing (SDK). Next, you create Kubernetes resources to train the model. After the training is complete, you create and deploy servers for inference using KFServing. This is how you use Kubeflow to establish an end-to-end agile process of a machine learning task. This process can be fully automated using pipelines, which help achieve DevOps in the AI field.
  • A cluster named clusterA has been created on CCE. The cluster has an available GPU node that has two or more GPUs.
  • EIPs have been bound to the nodes, and the kubectl command line tool has been configured. For details, see Connecting to a Cluster Using kubectl.
Installing Kustomize
Kustomize is an open-source tool used to manage the configuration of applications running in Kubernetes clusters. It allows you to modify application configuration. Starting with Kubeflow 1.3, all components should be deployed only using Kustomize.
  1. Install Kustomize. Kubeflow is incompatible with earlier versions of Kustomize. Therefore, only Kustomize 5 and later versions are supported. In this example, Kubeflow 5.1.0 is used.
    curl -o install_kustomize.sh "https://raw.githubusercontent.com/kubernetes-sigs/kustomize/master/hack/install_kustomize.sh"
    sh install_kustomize.sh 5.1.0 .
    The installation may take 3 to 5 minutes, and the information similar to the following will be displayed:
    v5.1.0
    kustomize installed to /root/kubeflow/./kustomize
  2. Move kustomize to the /bin directory so that the kustomize command can be used globally.
    cp kustomize /bin/
Installing Kubeflow
Perform the steps in this section to install all official Kubeflow components. After the installation, you can access the Kubeflow central dashboard. For details, see Connecting to Kubeflow.
  1. Install Kubeflow 1.7.0.
    wget https://github.com/kubeflow/manifests/archive/refs/tags/v1.7.0.zip
    unzip v1.7.0.zip
  2. Use Kustomize to create a YAML file for deploying Kubeflow.
    cd ./manifests-1.7.0/
    kustomize build example -o example.yaml
  3. Configure storage resources required by Kubeflow.
    • katib-mysql
    • mysql-pv-claim
    • minio-pv-claim
    • authservice-pvc
    Some storage resources need to be configured during the installation. The storage configuration in the official example cannot take effect in CCE. This may result in the preceding PVC fail to be created. Therefore, create a PVC with the same name in the cluster in advance. In this example, the EVS disk is used. You can change the storage type as required.
    Create the pvc.yaml file. The following is an example:
    apiVersion: v1
    kind: PersistentVolumeClaim
      namespace: kubeflow
      annotations:
        everest.io/disk-volume-type: SAS    # EVS disk type
      labels:
        failure-domain.beta.kubernetes.io/region: <your_region>   # Region of the node where the application is to be deployed
        failure-domain.beta.kubernetes.io/zone: <your_zone>       # AZ of the node where the application is to be deployed
      accessModes:
        - ReadWriteOnce
      resources:
        requests:
          storage: 10Gi
      storageClassName: csi-disk
    apiVersion: v1
      namespace: kubeflow
      annotations:
      labels:
      accessModes:
        - ReadWriteOnce
      resources:
        requests:
          storage: 20Gi
    apiVersion: v1
      namespace: kubeflow
      annotations:
      labels:
      accessModes:
        - ReadWriteOnce
      resources:
        requests:
          storage: 20Gi
    apiVersion: v1
      namespace: istio-system
      annotations:
      labels:
      accessModes:
        - ReadWriteOnce
      resources:
        requests:
          storage: 10Gi
    Create a PVC.
    kubectl apply -f pvc.yaml
  4. Create related resources.
    kubectl apply -f example.yaml
    Official images may fail to be pulled due to network problems, and the ImagePullBackOff or FailedPullImage error may occur in the workload. In this case, add a proper image proxy.
  5. Check whether pods in all namespaces are running.
    kubectl get pod -A
    If an unexpected problem occurs during resource creation, rectify it by referring to Common Issues.
Common Issues
  • In some scenarios where CRD resources do not exist, the following information is displayed:
    error: resource mapping not found for name: "<RESOURCE_NAME>" namespace: "<SOME_NAMESPACE>" from "STDIN": no matches for kind "<CRD_NAME>" in version "<CRD_FULL_NAME>"
    ensure CRDs are installed first
    Solution:
    This is because kustomization creates CRs ahead of CRDs. If you encounter this error message, create the resource again.
  • When a workload is created, an error message is displayed, indicating that there are too many pods on the node. The error message is displayed as follows:
    0/x nodes are available: x Too many pods.
    Solution:
    This message indicates that the number of schedulable pods on the node exceeds the node's upper limit. To solve this problem, increase the number of nodes.
  • The training-operator workload cannot run properly. The error message in the log is displayed as follows:
    Waited for 1.039518449s due to client-side throttling, not priority and fairness, request: GET:https://10.247.0.1:443/apis/xxx/xx?timeout=32s
    Solution:
    Run the following command to check the statuses of the unavailable APIServices in the cluster:
    kubectl get apiservice
    If there is no APIService in the FALSE state, the training-operator workload will run 1 to 2 minutes later.
