Configuring Domain Name Resolution for a CCE Container
This section describes how to configure domain name resolution for a container.
Service
- Create a Service before creating a workload (Deployment or ReplicaSet). When Kubernetes starts a container, it provides environment variables that point to all the Services that are running when the container is started. For example, if a Service named foo exists, all containers will obtain the following variables when they are initialized.
FOO_SERVICE_HOST=<the host the Service is running on> FOO_SERVICE_PORT=<the port the Service is running on>
Therefore, you must create a Service first. Otherwise, the environment variables do not take effect. This restriction does not apply to DNS.
- CCE clusters provide the CoreDNS add-on as the DNS server. The DNS server monitors the Kubernetes APIs for the new Services and creates a set of DNS records for each Service. If DNS is enabled throughout a cluster, all pods will be able to automatically resolve the names of Services.
- Do not specify a hostPort for a pod unless necessary. When a pod is bound to a hostPort, the number of locations to which the pod can be scheduled will be limited because each <hostIP, hostPort, protocol> must be unique. If you do not specify hostIP and protocol, Kubernetes uses 0.0.0.0 as the default host IP address and TCP as the default protocol.
If you only need to access the port for debugging, you can use apiserver proxies or kubectl port-forward.
If you want to open the pod port on the node, consider using a NodePort Service before using hostPort.
- Do not use hostNetwork. The reason is the same as that of using hostPort.
- When kube-proxy load balancing is not required, use headless Services (ClusterIP set to None) for service discovery.
DNS
By default, CCE provides a DNS add-on Service named coredns to automatically assign DNS domain names for other Services. If it is running in the cluster, run the following command to check the status:
kubectl get services coredns --namespace=kube-system NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE kube-dns ClusterIP 10.0.0.10 <none> 53/UDP,53/TCP 8m
If it is not running, run the kubec describe command to check the reason why the pod is not started. Assume that there is a Service that has an assigned permanent IP address and a DNS server (the CoreDNS add-on) that assigns a domain name to the IP address. In this way, any pod in the cluster can communicate with the Service. You can run another application for testing. Start a new pod, access it, and run the curl command to check whether the domain name of the Service can be properly resolved. In some cases, the curl command cannot be executed due to the DNS search principles and configuration.
When a pod is created on the CCE console, not all dnsConfig configurations are enabled and some default values of the pod domain name resolution parameters are used. You need to know well the default configurations. A typical case is ndots. If the number of dots is within the ndots threshold range, the domain name is considered as an internal domain name of the Kubernetes cluster and the ..svc.cluster.local suffix is added to the domain name.
DNS Search Principles and Rules
DNS configuration file: /etc/resolv.conf
nameserver 10.247.x.x search default.svc.cluster.local svc.cluster.local cluster.local options ndots:3
Parameters:
- nameserver: domain name resolution server
- search: domain name suffix search rule. More search configurations indicate more matching times for domain name resolution. For example, if three suffixes are matched, at least six search operations are required because both IPv4 and IPv6 addresses need to be checked.
- options: domain name resolution option. Multiple KV values are available. A typical case is ndots. If the number of dots in the domain name to be accessed exceeds the value of ndots, the domain name is considered as a complete domain name and is directly parsed. If the number of dots is less than the value of ndots, the suffix ..svc.cluster.local will be added.
Parameters in Kubernetes dnsConfig
- nameservers: a list of IP addresses that will be used as DNS servers for the pod. A maximum of three IP addresses can be specified. If pod's dnsPolicy is set to None, the list must contain at least one IP address, otherwise this property is optional. The servers listed will be combined to the base nameservers generated from the specified DNS policy with duplicate addresses removed.
- searches: a list of DNS search domains for hostname lookup in the pod. This property is optional. When specified, the provided list will be merged into the base search domain names generated from the chosen DNS policy. Duplicate domain names are removed. Kubernetes allows for at most 6 search domains.
- options: an optional list of objects where each object may have a name property (required) and a value property (optional). The contents in this property will be merged to the options generated from the specified DNS policy. Duplicate entries are removed.
For details, see DNS for Services and Pods.
Pod DNS Policies
DNS policies can be configured on a per-pod basis. Supported DNS policies are Default, ClusterFirst, and None.
- Default: The DNS configuration of a pod inherits from the host. That is, the DNS configuration of the pod is the same as that of the node.
- ClusterFirst: Unlike the Default policy, the ClusterFirst policy writes kube-dns (or CoreDNS) information to the DNS configuration of a pod in advance. ClusterFirst is the default pod policy. If PodPolicy is not specified for the pod, dnsPolicy is preset to ClusterFirst. However, ClusterFirst is mutually exclusive with HostNetwork=true. If HostNetwork is set to true, the ClusterFirst policy will be forcibly changed to the Default policy.
- None: This policy will clear the DNS configuration preset for a pod. If dnsPolicy is set to None, Kubernetes does not load any DNS configuration that is determined by its own logic in advance for the pod. Therefore, if you want to set dnsPolicy to None, you are advised to set dnsConfig to describe custom DNS parameters. This setting ensures that the pod has DNS configuration.
DNS configuration scenarios are provided as follows:
Scenario 1: Using a custom DNS
The example below allows you to use a custom DNS to resolve the application domain names in pods. After an application migration, you do not need to modify the configuration.
apiVersion: v1
kind: Pod
namespace: default
containers:
- name: test
image: nginx
dnsPolicy: "None"
dnsConfig:
nameservers:
- 1.2.3.4
searches:
- ns1.svc.cluster.local
- my.dns.search.suffix
options:
- name: ndots
value: "2"
- name: edns0 Scenario 2: Using the Kubernetes CoreDNS
The DNS service of Kubernetes is preferentially used for domain name resolution. If the resolution fails, the DNS service of an external cascading system is used for domain name resolution.
apiVersion: v1
kind: Pod
namespace: default
containers:
- name: test
image: nginx
dnsPolicy: ClusterFirst Scenario 3: Using the Internet domain name resolution
This mode applies to the scenario where the domain names in pods are to be accessed from the Internet. In this case, the applications in the pods resolve domain names from an external DNS.
apiVersion: v1
kind: Pod
namespace: default
containers:
- name: test
image: nginx
dnsPolicy: Default Scenario 4: Using hostNetwork
If hostNetwork: true is used to configure the pod network, the network interfaces on the host node are exposed to the application pod. All network interfaces on the LAN where the host node is located can be used to access the application.
apiVersion: extensions/v1beta1
kind: Deployment
template:
labels:
app: nginx
hostNetwork: true
dnsPolicy: ClusterFirstWithHostNet
containers:
- name: nginx
image: nginx:1.7.9
ports:
- containerPort: 80 If dnsPolicy: ClusterFirstWithHostNet is not added, even if the pod uses the DNS of the host node by default, it cannot access other pods in the Kubernetes cluster through the Service.
CoreDNS Configuration
1. Configuring a CoreDNS ConfigMap
The default CoreDNS configuration file is as follows:
Corefile: |
.:53 {
errors
health
kubernetes cluster.local in-addr.arpa ip6.arpa {
pods insecure
upstream
fallthrough in-addr.arpa ip6.arpa
prometheus :9153
forward . /etc/resolv.conf
cache 30
loop
reload
loadbalance Where:
- error: Errors are recorded to stdout.
- health: The CoreDNS running status report can be obtained from http://localhost:8080/health.
- kubernetes: The CoreDNS returns a DNS query response based on the IP addresses of the Kubernetes Service and pod.
- prometheus: The measurement standard of CoreDNS can be found in the metrics in the format of http://localhost:9153/Prometheus. You can obtain monitoring data in Prometheus format from http://localhost:9153/metrics.
- proxy and forward: Any query that is not in the Kubernetes cluster domain is forwarded to the predefined resolver (/etc/resolv.conf). If the domain name cannot be resolved locally, query the upper-level address. By default, the /etc/resolv.conf configuration of the host machine is used.
- cache: The front-end cache is enabled.
- loop: Simple forwarding loops are detected. If a loop is detected, the CoreDNS process is stopped.
- reload: The changed Corefile can be automatically reloaded. After editing the ConfigMap, wait for two minutes for the modification to take effect.
- loadbalance: This is a round-robin DNS load balancer that randomizes the order of A, AAAA, and MX records in the answer.
2. Configuring an external DNS server
Some services are not in the Kubernetes environment and need to be accessed through the DNS. The name suffix is carey.com.
carey.com:53 {
errors
cache 30
proxy . 10.150.0.1
} Complete configuration file:
Corefile: |
.:53 {
errors
health
pods insecure
upstream
prometheus :9153
cache 30
loop
reload
loadbalance
carey.com:53 {
errors
cache 30
proxy . 10.150.0.1
} CCE supports stub domains, which are more flexible and convenient than directly editing ConfigMaps. With stub domains, you do not need to pay attention to the domain name resolution configuration of pods.
