Using a Custom Storage Class
Background
When using storage resources in CCE, the most common method is to specify storageClassName to define the type of storage resources to be created when creating a PVC. The following configuration shows how to use a PVC to apply for an SAS (high I/O) EVS disk (block storage).
apiVersion: v1
kind: PersistentVolumeClaim
namespace: default
annotations:
everest.io/disk-volume-type: SAS
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 10Gi
storageClassName: csi-disk To specify the EVS disk type, configure the everest.io/disk-volume-type field. The value SAS is used as an example here, indicating a high I/O EVS disk. You can also choose SSD (ultra-high I/O).
This configuration method may not work if you want to:
- Configure storageClassName only, which is simpler than specifying the EVS disk type by using everest.io/disk-volume-type.
- Avoid modifying YAML files or Helm charts. Some users switch from self-built or other Kubernetes services to CCE and have written YAML files of many applications. In these YAML files, different types of storage resources are specified by different storage class names. When using CCE, they need to modify a large number of YAML files or Helm charts to use storage resources, which is labor-consuming and error-prone.
- Use the default storageClassName for all applications. In this way, you can create storage resources of the default type without needing to specify storageClassName in the YAML file.
Solution
This section describes how to configure a custom storage class and the default storage class. You can specify different types of storage resources by setting storageClassName.
- For the first scenario, you can define custom storage class names for SAS and SSD EVS disks. For example, define a storage class named csi-disk-sas for creating SAS disks. The figure below shows the differences before and after you use a custom storage class. When writing a YAML file, you only need to specify storageClassName. This meets the usage habits of specific users.
- For the second scenario, you can define a storage class with the same name as that in the existing YAML file without modifying storageClassName in the YAML file.
- For the third scenario, you can set the default storage class as described below to create storage resources without specifying storageClassName in the YAML file.
apiVersion: v1 kind: PersistentVolumeClaim metadata: name: pvc-evs-example namespace: default spec: accessModes: - ReadWriteOnce resources: requests: storage: 10Gi
Creating a StorageClass Using a YAML File
As of now, CCE provides StorageClasses such as csi-disk, csi-nas, and csi-obs by default. When defining a PVC, you can use a StorageClassName to automatically create a PV of the corresponding type and automatically create underlying storage resources.
Run the following kubectl command to obtain the StorageClasses that CCE supports. Use the CSI add-on provided by CCE to create a StorageClass.
# kubectl get sc NAME PROVISIONER AGE csi-disk everest-csi-provisioner 17d # EVS disk csi-disk-topology everest-csi-provisioner 17d # EVS disks created with a delay csi-nas everest-csi-provisioner 17d # SFS 1.0 csi-sfs everest-csi-provisioner 17d # A general purpose file system (SFS 3.0 Capacity-Oriented) csi-obs everest-csi-provisioner 17d # OBS csi-sfsturbo everest-csi-provisioner 17d # SFS Turbo csi-local everest-csi-provisioner 17d # Local PV csi-local-topology everest-csi-provisioner 17d # Local PV created with a delay csi-disk-dss everest-csi-provisioner 2d21h # DSS
kind: StorageClass apiVersion: storage.k8s.io/v1 metadata: name: csi-disk provisioner: everest-csi-provisioner parameters: csi.storage.k8s.io/csi-driver-name: disk.csi.everest.io csi.storage.k8s.io/fstype: ext4 everest.io/disk-volume-type: SAS everest.io/passthrough: 'true' reclaimPolicy: Delete allowVolumeExpansion: true volumeBindingMode: Immediate
| Parameter | Description |
| provisioner | Specifies the storage resource provider, which is the Everest add-on for CCE. Set this parameter to everest-csi-provisioner. |
| parameters | Specifies the storage parameters, which vary with StorageClasses. For details, see Table 2. |
| reclaimPolicy | Specifies the value of persistentVolumeReclaimPolicy for creating a PV. The value can be Delete or Retain. If reclaimPolicy is not specified when a StorageClass object is created, the value defaults to Delete.
| allowVolumeExpansion | Specifies whether the PV of this StorageClass supports dynamic capacity expansion. The default value is false. Dynamic capacity expansion is implemented by the underlying storage add-on. This is only a switch. |
| volumeBindingMode | Specifies the volume binding mode, which is the time when a PV is dynamically created. The value can be Immediate or WaitForFirstConsumer.
| mountOptions | This field must be supported by the underlying storage. If this field is not supported but is specified, the PV creation will fail. |
| Volume Type | Parameter | Mandatory | Description |
| EVS | csi.storage.k8s.io/csi-driver-name | Yes | Driver type. If an EVS disk is used, the parameter value is fixed at disk.csi.everest.io. |
| EVS | csi.storage.k8s.io/fstype | Yes | If an EVS disk is used, the parameter value can be ext4. |
| EVS | everest.io/disk-volume-type | Yes | EVS disk type. All letters are in uppercase.
| EVS | everest.io/passthrough | Yes | The parameter value is fixed at true, which indicates that the EVS device type is SCSI. No other parameter values are allowed. |
| EVS | everest.io/disk-iops | No | Preconfigured IOPS, which is supported only by general-purpose SSD v2 and extreme SSD v2 EVS disks.
| EVS | everest.io/disk-throughput | No | Preconfigured throughput, which is supported only by general-purpose SSD v2 EVS disks. The value ranges from 125 MiB/s to 1000 MiB/s. The maximum value is a quarter of IOPS. If the throughput is greater than 125 MiB/s, extra throughput will be billed. For details, see Price Calculator. |
| SFS | csi.storage.k8s.io/csi-driver-name | Yes | Driver type. If SFS is used, the parameter value is fixed at nas.csi.everest.io. |
| SFS | csi.storage.k8s.io/fstype | Yes | If SFS is used, the value can be nfs. |
| SFS | everest.io/share-access-level | Yes | The parameter value is fixed at rw, indicating that the SFS data is readable and writable. |
| SFS | everest.io/share-access-to | Yes | VPC ID of the cluster. |
| SFS | everest.io/share-is-public | No | The parameter value is fixed at false, indicating that the file is shared to private. When you use a general purpose file system (SFS 3.0 Capacity-Oriented), there is no need to configure this parameter. |
| SFS | everest.io/sfs-version | No | This parameter is only required for general purpose file systems (SFS 3.0 Capacity-Oriented) and its value is fixed at sfs3.0. |
| SFS Turbo | csi.storage.k8s.io/csi-driver-name | Yes | Driver type. If SFS Turbo is used, the parameter value is fixed at sfsturbo.csi.everest.io. |
| SFS Turbo | csi.storage.k8s.io/fstype | Yes | If SFS Turbo is used, the value can be nfs. |
| SFS Turbo | everest.io/share-access-to | Yes | VPC ID of the cluster. |
| SFS Turbo | everest.io/share-expand-type | No | Extension type. The default value is bandwidth, indicating an enhanced file system. This parameter does not take effect. |
| SFS Turbo | everest.io/share-source | Yes | The parameter value is fixed at sfs-turbo. |
| SFS Turbo | everest.io/share-volume-type | No | SFS Turbo StorageClass. The default value is STANDARD, indicating standard and standard enhanced editions. This parameter does not take effect. |
| SFS Turbo | everest.io/reclaim-policy | No | Whether to retain subdirectories when deleting a PVC. This parameter must be used with reclaimPolicy. This parameter is available only when the PV reclaim policy is Delete. Options:
| OBS | csi.storage.k8s.io/csi-driver-name | Yes | Driver type. If OBS is used, the parameter value is fixed at obs.csi.everest.io. |
| OBS | csi.storage.k8s.io/fstype | Yes | Instance type, which can be obsfs or s3fs.
| OBS | everest.io/obs-volume-type | Yes | OBS StorageClass.
| Local PV | csi.storage.k8s.io/csi-driver-name | Yes | Driver type. If a local PV is used, the parameter value is fixed at local.csi.everest.io. |
| Local PV | csi.storage.k8s.io/fstype | Yes | File system type. The value can only be ext4. |
| Local PV | volume-type | Yes | Volume type. The value can only be persistent. |
| DSS | csi.storage.k8s.io/csi-driver-name | Yes | Driver type. If DSS is used, the parameter value is fixed at disk.csi.everest.io. |
| DSS | csi.storage.k8s.io/fstype | Yes | File system type. The value can only be ext4. |
| DSS | everest.io/disk-volume-type | Yes | Dedicated storage, which must be specified in uppercase.
| DSS | everest.io/passthrough | Yes | The parameter value is fixed at true, which indicates that the DSS device type is SCSI. No other values are allowed. |
| DSS | everest.io/resource-type | Yes | Resource type. The parameter value is fixed at dss. |
Creating a Custom Storage Class
You can customize a high I/O storage class in a YAML file. For example, csi-disk-sas indicates that the disk type is SAS (high I/O).
apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: name: csi-disk-sas # Name of the high I/O storage class. You can use another name. parameters: csi.storage.k8s.io/csi-driver-name: disk.csi.everest.io csi.storage.k8s.io/fstype: ext4 everest.io/disk-volume-type: SAS # High I/O EVS disk type, which cannot be customized. everest.io/passthrough: "true" provisioner: everest-csi-provisioner reclaimPolicy: Delete volumeBindingMode: Immediate allowVolumeExpansion: true # true indicates that capacity expansion is allowed.
For an ultra-high I/O storage class, you can set the class name to csi-disk-ssd to create SSD EVS disk (ultra-high I/O).
apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: name: csi-disk-ssd # Name of the ultra-high I/O storage class. You can use another name. parameters: csi.storage.k8s.io/csi-driver-name: disk.csi.everest.io csi.storage.k8s.io/fstype: ext4 everest.io/disk-volume-type: SSD # Ultra-high I/O EVS disk type, which cannot be customized. everest.io/passthrough: "true" provisioner: everest-csi-provisioner reclaimPolicy: Delete volumeBindingMode: Immediate allowVolumeExpansion: true
reclaimPolicy: indicates the recycling policies of the underlying cloud storage. The value can be Delete or Retain.
- Delete: When a PVC is deleted, both the PV and the EVS disk are deleted.
- Retain: When a PVC is deleted, the PV and underlying storage resources are not deleted. Instead, you must manually delete these resources. After that, the PV is in the Released state and cannot be bound to the PVC again.
The reclaim policy configured here has no impact on the SFS Turbo volume, so it will not be reclaimed after cluster or PVC deletion.
If high data security is required, you are advised to select Retain to prevent data from being deleted by mistake.
After the definition is complete, run the kubectl create commands to create storage resources.
# kubectl create -f sas.yaml storageclass.storage.k8s.io/csi-disk-sas created # kubectl create -f ssd.yaml storageclass.storage.k8s.io/csi-disk-ssd created
Query the storage classes again. Two more types of storage classes are displayed in the command output, as shown below.
# kubectl get sc NAME PROVISIONER AGE csi-disk everest-csi-provisioner 17d csi-disk-sas everest-csi-provisioner 2m28s csi-disk-ssd everest-csi-provisioner 16s csi-disk-topology everest-csi-provisioner 17d csi-nas everest-csi-provisioner 17d csi-obs everest-csi-provisioner 17d csi-sfsturbo everest-csi-provisioner 17d
Other types of storage resources can be defined in the similar way. You can use kubectl to obtain the YAML file and modify it as required.
- File storage
# kubectl get sc csi-nas -oyaml kind: StorageClass apiVersion: storage.k8s.io/v1 metadata: name: csi-nas provisioner: everest-csi-provisioner parameters: csi.storage.k8s.io/csi-driver-name: nas.csi.everest.io csi.storage.k8s.io/fstype: nfs everest.io/share-access-level: rw everest.io/share-access-to: 5e3864c6-e78d-4d00-b6fd-de09d432c632 # ID of the VPC to which the cluster belongs everest.io/share-is-public: 'false' everest.io/zone: xxxxx # AZ reclaimPolicy: Delete allowVolumeExpansion: true volumeBindingMode: Immediate
- Object storage
# kubectl get sc csi-obs -oyaml kind: StorageClass apiVersion: storage.k8s.io/v1 metadata: name: csi-obs provisioner: everest-csi-provisioner parameters: csi.storage.k8s.io/csi-driver-name: obs.csi.everest.io csi.storage.k8s.io/fstype: s3fs # Object storage type. s3fs indicates an object bucket, and obsfs indicates a parallel file system. everest.io/obs-volume-type: STANDARD # Storage class of the OBS bucket reclaimPolicy: Delete volumeBindingMode: Immediate
Specifying an Enterprise Project for a Storage Class
CCE allows you to specify an enterprise project when creating EVS and OBS PVCs. The created storage resources (EVS disks and OBS buckets) belong to the specified enterprise project. The enterprise project can be the one to which the cluster belongs or the default enterprise project.
If you do not specify an enterprise project, the StorageClass enterprise project is used by default. Storage resources created using the csi-disk and csi-obs StorageClasses of CCE belong to the default enterprise project.
If you want the storage resources created from the storage classes to be in the same enterprise project as the cluster, you can customize a storage class and specify the enterprise project ID, as shown below.
To use this function, the CCE Container Storage (Everest) add-on must be upgraded to 1.2.33 or later.
kind: StorageClass apiVersion: storage.k8s.io/v1 metadata: name: csi-disk-epid # Enter a storage class name. provisioner: everest-csi-provisioner parameters: csi.storage.k8s.io/csi-driver-name: disk.csi.everest.io csi.storage.k8s.io/fstype: ext4 everest.io/disk-volume-type: SAS everest.io/enterprise-project-id: 86bfc701-9d9e-4871-a318-6385aa368183 #Specify the enterprise project ID. everest.io/passthrough: 'true' reclaimPolicy: Delete allowVolumeExpansion: true volumeBindingMode: Immediate
Specifying a Storage Class as the Default One
You can specify a storage class as the default class. In this way, if you do not specify storageClassName when creating a PVC, the PVC is created using the default storage class.
For example, to specify csi-disk-ssd as the default storage class, edit your YAML file as follows:
kind: StorageClass
annotations:
storageclass.kubernetes.io/is-default-class: "true" # Specifies the default storage class in a cluster. A cluster can have only one default storage class.
parameters:
allowVolumeExpansion: true Delete the created csi-disk-ssd disk, run the kubectl create command to create a csi-disk-ssd disk again, and then query the storage class. The following information is displayed:
# kubectl delete sc csi-disk-ssd storageclass.storage.k8s.io "csi-disk-ssd" deleted # kubectl create -f ssd.yaml storageclass.storage.k8s.io/csi-disk-ssd created # kubectl get sc NAME PROVISIONER AGE csi-disk everest-csi-provisioner 17d csi-disk-sas everest-csi-provisioner 114m csi-disk-ssd (default) everest-csi-provisioner 9s csi-disk-topology everest-csi-provisioner 17d csi-nas everest-csi-provisioner 17d csi-obs everest-csi-provisioner 17d csi-sfsturbo everest-csi-provisioner 17d
Verification
You can use either of the following methods to create a PVC:
- Specify a storage class explicitly.
- Use the default storage class in the cluster if you do not specify a storage class.
The steps to check the results of both methods are shown below.
