Help Center/ Cloud Container Engine/ Best Practices/ Networking/ Implementing Network Communications Between Containers and IDCs Using VPC and Direct Connect
Updated on 2025-10-30 GMT+08:00
Application Scenarios
With VPC and Direct Connect, the container CIDR block (172.56.0.0/16) and IDC CIDR block (10.1.123.0/24) can communicate with each other in the cluster using the VPC network model.
Figure 1 Example network topology
Table 1 Address information
CIDR Block
User's IDC network
10.1.123.0/24
Remote and local gateways (addresses for interconnection)
Huawei Cloud: 10.0.0.1/30
User: 10.0.0.2/30
VPC
192.168.0.0/16
Container CIDR block
172.56.0.0/16
An IDC is available, and the Direct Connect service has been applied for.
  1. Create a connection.
    1. Log in to the management console, click in the upper left corner, and select the desired region and project. Click in the upper left corner and choose Networking > Direct Connect in the expanded list.
    2. In the navigation pane on the left of the console, choose Direct Connect > Connections. On the displayed page, click Create Connection.
    3. Enter the equipment room details and select the Direct Connect location and port based on Table 2.
      Table 2 Parameters required for creating a cloud connection
      Billing Mode
      Specifies how you are charged. Currently, only Yearly/Monthly is supported.
      Region
      Specifies the region where the connection is deployed. You can change the region in the upper left corner of the console.
      Connection Name
      Specifies the name of your connection.
      Location
      Specifies the Direct Connect location where your leased line can be connected to.
      Carrier
      Specifies the carrier that provides the leased line.
      Port Type
      Specifies the type of the port used by the connection. There are four types of ports: 1GE, 10GE, 40GE, and 100GE.
      Leased Line Bandwidth
      Specifies the bandwidth of the connection in the unit of Mbit/s. This is the bandwidth of the leased line you have purchased from the carrier.
      Equipment Room Address
      Specifies the address of your equipment room. The address must be specific to the floor your equipment room is on, for example, XX Equipment Room, XX Building, No. XX, Huajing Road, Pudong District, Shanghai.
      Tag
      Identifies the connection. A tag consists of a key and a value. You can add 10 tags to a connection.
      If a predefined tag has been created on TMS, you can directly select the corresponding tag key and value.
      For details about predefined tags, see Predefined Tag Overview.
      Provides supplementary information about the connection.
      Required Duration
      Specifies how long the connection will be used.
      Auto-renew
      Specifies whether to automatically renew the connection to ensure service continuity.
      It is recommended that you set the auto-renewal period to be the same as the required duration. If the required duration is three months, the system automatically renews the subscription for every three months.
      Enterprise Project
      Centrally manages cloud resources and members by project.
    4. Click Confirm Configuration.
    5. Confirm the order and click Pay Now.
    6. Click Confirm.
  2. Create a virtual gateway.
    1. Choose Direct Connect > Virtual Gateways, and click Create Virtual Gateway on the right. Add the VPC CIDR block and the container CIDR block in the VPC network model.
      Figure 2 Creating a virtual gateway
      Table 3 Virtual gateway parameters
      Name
      Specifies the virtual gateway name.
      You can enter 1 to 64 characters.
      Enterprise Project
      Attach To
      Select VPC.
      VPC
      Specifies the VPC you want to access using the connection.
      Local Subnet
      Specifies the CIDR blocks of subnets in the VPC to connect to the on-premises network.
      In this example, the cluster uses the VPC network model. Enter the VPC CIDR block (192.168.0.0/16) and container CIDR block (172.56.0.0/16). For clusters using the container tunnel network and Cloud Native 2.0 Network models, you only need to enter the VPC CIDR block.
      Provides supplementary information about the virtual gateway.
      The description can contain a maximum of 128 characters.
    2. Click OK.
      When the virtual gateway status changes Normal, the virtual gateway has been created.
  3. Create a virtual interface.
    1. Choose Direct Connect > Virtual Interfaces, and click Create Virtual Interface on the right.
    2. Configure the parameters based on Table 4.
      Figure 3 Creating a virtual interface
      Table 4 Parameters required for creating a virtual interface
      Region
      Name
      Specifies the virtual interface name.
      Connection
      Specifies the connection you use to connect your data center to the cloud.
      Virtual Gateway
      Specifies the virtual gateway that the virtual interface connects to.
      VLAN
      Specifies the VLAN of the virtual interface.
      Configure the VLAN if you create a connection on your own.
      The VLAN for a hosted connection will be allocated by the carrier or partner. You do not need to configure the VLAN.
      Bandwidth
      Specifies the bandwidth that can be used by the virtual interface in the unit of Mbit/s. The bandwidth cannot exceed that of the connection.
      Enterprise Project
      Local Gateway
      Specifies the IP address for connecting to the cloud.
      In this example, the IP address is 10.0.0.1/30.
      Remote Gateway
      Specifies the IP address for connecting to your on-premises network.
      The remote gateway must be in the same IP address range as the local gateway. Generally, a subnet with a 30-bit mask is recommended.
      In this example, the IP address is 10.0.0.2/30.
      Remote Subnet
      Specifies the subnets of your on-premises network. If multiple remote subnets are available, use commas (,) to separate them.
      In this example, the IP address is 10.1.123.0/24.
      Routing Mode
      Specifies the routing mode. Two options are available, Static and BGP.
      If there are two or more connections, select BGP routing.
      BGP ASN
      Specifies the ASN of the BGP peer.
      This parameter is mandatory when you select BGP routing.
      BGP MD5 Authentication Key
      Specifies the password used to authenticate the BGP peer using MD5.
      This parameter is mandatory when BGP routing is selected, and the parameter values on both gateways must be the same.
      The key contains 8 to 255 characters and must contain at least two types of the following characters:
      • Uppercase letters
      • Lowercase letters
      • Digits
      • Special characters ~!, .:;-_"(){}[]/@#$ %^&*+\|=
      Provides supplementary information about the virtual interface.
    3. Click Create Now. When the status of the virtual interface changes to Normal, the virtual interface has been created.
    4. Ping the IP address of a server in the VPC from your data center to test network connectivity.
      Now your environment can connect to the cloud and access the desired VPC.
      After creating a virtual interface, configure your devices and security group rules to allow access on and off the cloud.
  4. Test the connectivity.
    1. Run the traceroute command to check whether the IDC host can communicate with the container.
      1. If the route is normal, Direct Connect has a return route.
      2. If the IDC route to the cloud gateway of Direct Connect is abnormal, check whether the route settings at both ends of Direct Connect are correct.
    2. If the IP address cannot be tracerouted, try the ping or telnet operation. Before pinging the address, ensure that the ICMP policy has been enabled for the security group if the target is an ECS.
