Help Center/ Cloud Container Engine/ Best Practices/ Networking/ Enabling Sticky Sessions Through Load Balancing
Updated on 2026-03-10 GMT+08:00
Concepts
Sticky sessions ensure continuity and consistency when you access applications. If a load balancer is deployed between a client and backend servers, connections may be forwarded to different servers for processing. Sticky sessions can resolve this issue. After sticky sessions are enabled, requests from the same client will be continuously distributed to the same backend server through load balancing.
For example, in most online systems that require user identity authentication, a user needs to interact with the server multiple times to complete a session. These interactions require continuity. If sticky sessions are not configured, the load balancer may allocate certain requests to different backend servers. Since user identity has not been authenticated on other backend servers, interaction exceptions such as a user login failure may occur.
Therefore, select a proper sticky session type based on the application environment.
Table 1 Sticky session types
OSI Layer
Listener Protocol and Networking
Sticky Session Type
Scenarios Where Sticky Sessions Become Invalid
Layer 4
TCP- or UDP-compliant Services
Source IP address: The source IP address of each request is used as the hash key to map the needed server from the static hash table. This means that all access requests from the same IP address will be forwarded to the same backend server for processing.
  • Source IP addresses of the clients have changed.
  • Requests from the clients exceed the session stickiness duration.
Layer 7
HTTP- or HTTPS-compliant ingresses
  • Load balancer cookie: The load balancer generates a cookie after receiving a request from the client. All subsequent requests with the cookie will be routed to the same backend server.
  • Application cookie: The application deployed on the backend server generates a cookie after receiving the first request from the client. All subsequent requests with the same cookie will be routed to the same backend server.
  • Requests from the clients do not contain any cookie.
When creating a load balancer, configure sticky sessions by setting kubernetes.io/elb.lb-algorithm to ROUND_ROBIN or kubernetes.io/elb.lb-algorithm to LEAST_CONNECTIONS. If you set kubernetes.io/elb.lb-algorithm to SOURCE_IP, source IP address-based sticky sessions are supported. In this case, you do not need to configure sticky sessions again.
Layer 4 Sticky Sessions for Services
In Layer 4 mode, source IP address-based sticky sessions can be enabled, where hash routing is performed based on the client IP addresses.
Layer 7 Sticky Sessions for Ingresses
In Layer 7 mode, sticky sessions can be enabled using HTTP cookies or application cookies.
