Help Center/ Cloud Container Engine/ Best Practices/ Container/ Modifying Kernel Parameters Using a Privileged Container
Updated on 2026-05-21 GMT+08:00
To access a Kubernetes cluster from a client, you can use the Kubernetes command line tool kubectl. For details, see Accessing a Cluster Using kubectl.
  1. Create a DaemonSet on the backend, select the Nginx image, enable the privileged container, configure the lifecycle, and specify hostNetwork: true.
    1. Create a DaemonSet YAML file.
      vi daemonset.yaml
      An example YAML file is provided as follows:
      The spec.spec.containers.lifecycle field indicates the command that will be run after the container is started.
      kind: DaemonSet
      apiVersion: apps/v1
        labels:
        selector:
          matchLabels:
        template:
            labels:
            hostNetwork: true
            containers:
            - name: daemonset-test
              image: nginx:alpine-perl
              command:
              - "/bin/sh"
              args:
              - "-c"
              - while :; do  time=$(date);done
              imagePullPolicy: IfNotPresent
              lifecycle:
                postStart:
                  exec:
                    command:
                    - sysctl
                    - "-w"
                    - net.ipv4.tcp_tw_reuse=1
              securityContext:
                privileged: true
            imagePullSecrets:
            - name: default-secret
    2. Create the DaemonSet.
      kubectl create –f daemonSet.yaml
  2. Check whether the DaemonSet has been created.
    kubectl get daemonset {daemonset_name}
    In this example, run the following command:
    kubectl get daemonset daemonset-test
    Information similar to the following is displayed:
    NAME               DESIRED    CURRENT   READY    UP-TO-DATE    AVAILABLE     NODE SELECTOR   AGE
    daemonset-test     2          2         2        2             2             <node>          2h
  3. Obtain the IDs of the DaemonSet pods on the nodes.
    kubectl get pod | grep {daemonset_name}
    kubectl get pod | grep daemonset-test
    daemonset-test-mqdpv               1/1     Running             0          2h
    daemonset-test-n56vm               1/1     Running             0          2h
  4. Access the pod.
    kubectl exec -it {pod_name} -- /bin/sh
    kubectl exec -it daemonset-test-mqdpv -- /bin/sh
  5. Check whether the configured command is executed after the pod is started.
    sysctl -a |grep net.ipv4.tcp_tw_reuse
    If information similar to the following is displayed, the system parameters have been modified:
