Configuration Suggestions on Container Network Bandwidth Limit
Application Scenarios
Containers on the same node share the host network bandwidth. Limiting the network bandwidth of containers can effectively prevent mutual interference between containers and improve container network stability.
Notes and Constraints
Specifications |
Tunnel Network |
VPC Network |
Cloud Native Network 2.0 |
VPC + DataPlane V2 |
Cloud Native Network 2.0 + DataPlane V2 |
Supported cluster versions |
All versions |
Clusters of v1.19.10 and later |
Cluster version: v1.27.16-r30, v1.28.15-r20, v1.29.13-r0, v1.30.10-r0, v1.31.6-r0, or later |
Cluster version: v1.27.16-r10, v1.28.15-r0, v1.29.10-r0, v1.30.6-r0, or later |
Egress bandwidth limitation |
Supported |
Supported |
Supported |
Supported |
Supported |
Ingress bandwidth limitation |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Scenarios where bandwidth limitation is not supported |
None |
None |
Mutual access between pods on the host node |
Bandwidth limitation range |
Only the rate limit in the unit of Mbit/s or Gbit/s is supported, for example, 100 Mbit/s or 1 Gbit/s. The minimum value is 1 Mbit/s and the maximum value is 4.29 Gbit/s. |
The minimum value is 1 kbit/s, and the maximum value is 1 Pbit/s. |
- After DataPlane V2 network acceleration is enabled, pods on the nodes running Huawei Cloud EulerOS 2.0 use EDT to limit the egress bandwidth. The ingress bandwidth limitation is not supported. In other network modes, a Token Bucket Filter (TBF) qdisc is used to limit the bandwidth.
- Pod bandwidth limitation applies to regular containers (runC as the container runtime), not secure containers (Kata Containers as the container runtime).
- Pod bandwidth limitation does not apply to hostNetwork pods.
- Edit a YAML file for a workload.
vi deployment.yaml
Set the network bandwidth for the pod in spec.template.metadata.annotations to limit the network traffic of the container. For details about the network bandwidth limit fields, see Table 1.
If the parameters are not specified, the network bandwidth is not limited by default.
An example is as follows:
apiVersion: apps/v1 kind: Deployment metadata: name: nginx spec: replicas: 1 selector: matchLabels: app: nginx strategy: type: RollingUpdate template: metadata: labels: app: nginx annotations: # Ingress bandwidth kubernetes.io/ingress-bandwidth: 100M # Egress bandwidth kubernetes.io/egress-bandwidth: 1G spec: containers: - image: nginx imagePullPolicy: Always name: nginx imagePullSecrets: - name: default-secretTable 1 Fields for limiting the network bandwidth of pods Field
Mandatory
Ingress bandwidth for a pod.
Value range: 1k-1P. If this field is set to a value greater than 32 Gbit/s, the actual ingress bandwidth that a pod can use is 32 Gbit/s.
No
Egress bandwidth for a pod.
Value range: 1k-1P. If this field is set to a value greater than 32 Gbit/s, the actual egress bandwidth that a pod can use is 32 Gbit/s.
No
- Create a workload.
kubectl create -f deployment.yaml
Information similar to the following is displayed:
deployment.apps/nginx created
