- Billing
- Getting Started
User Guide
- Overview
- Permissions Management
- Environment Management
- Application Management
- Component Management
- Instance Management
- Component Configurations
- Component O&M
- System Settings
- Key Operations Recorded by CTS
Best Practices
- CAE Best Practices
- Using CAE to Host Nginx Static File Servers
- Interconnecting GitLab with Jenkins for Automatic Build and Deployment on CAE
- Deploying Components Based on the Dependency Sequence Using the Jenkins Pipeline
- Deploying Spring Cloud Applications to CAE to Automatically Connect to the Nacos Engine
- Graceful Startup of a Spring Cloud Application
- Health Check
- Lifecycle Management
- Sending Event Alarms to WeCom
Connecting to the CodeArts Pipeline to Automatically Upgrade CAE Components
- Overview
- Upgrading a CAE Component After Uploading a Software Package Built Using the Pipeline to a CodeArts Release Repo
- Upgrading a CAE Component After Uploading a Software Package Built Using the Pipeline to the OBS Bucket
- Upgrading a CAE Component After Uploading an Image Built Using the Pipeline to the SWR Image Repository
- Configuring PromQL to Implement Custom Auto Scaling
- Configuring the Interconnection Between CAE and DEW to Help Applications Obtain Encrypted Secrets from DEW
- Deploying ASP.NET Core Applications to CAE
- Connecting the Network Through Enterprise Routes
- API Reference
- Component Management FAQs
Component Configuration FAQs
- Is Manual Scaling Still Effective When a Scaling Policy Is Configured?
- Can Components Be Scaled Without a Scaling Policy?
- Why Is My Instance Abnormal After Cloud Storage Is Configured?
- What Do I Do If a Component Becomes Not Ready?
- How Does CAE Support Dark Launch?
- How Do I Provide Prometheus Metrics for a Java Application?
- System Configuration FAQs
- Service Resources FAQs
Overview
Application Scenario
This service is used to host web frontend components of service code and static pages. Create an image for service code and deploy it to CAE, and store the static files in the parallel file system associated with a component. In this way, you can host the frontend components of services and static files. After components are deployed, you can update static page files in the parallel file system to update frontend applications in real time.
This solution uses Nginx alpine-perl, which has been provided in the open-source image.
Architecture
Nginx is a lightweight web server and an HTTP server for static resources. This practice uses Nginx to describe how to configure a parallel file system in the cloud storage to host static files and update these static files to update the Nginx access page in real time.
Default Nginx Configurations
Figure 3 shows the default Nginx configurations.
The Nginx configuration file (nginx.conf) of this tag is /etc/nginx/nginx.conf.
Figure 4 shows the default.conf file of Nginx. /usr/share/nginx/html stores static files. There are two default files in this path: 50x.html and index.html.
To replace the page display, place the HTML file to be replaced in the /usr/share/nginx/html directory. The HTML file can be downloaded from Obtaining a Static File.
