Updated on 2025-11-03 GMT+08:00
Overview
This document summarizes practices in common application scenarios of API Gateway (APIG). Each practice case is given detailed solution description and operation guidance, helping you easily build your services based on APIG.
Table 1 APIG best practices
Practice
Selectively Exposing CCE Workloads with a Dedicated Gateway
You can use APIG to selectively expose your workloads and microservices in Cloud Container Engine (CCE).
Selectively Exposing Service Capabilities of a Data Center Using a Dedicated Gateway
You can use APIG to set up a connection between your on-premises data center and the gateway (or the VPC bound to the gateway).
Exposing Backend Services Across VPCs Using a Dedicated Gateway
If the VPC of your backend server is different from that of your gateway, you can expose your backend service through cross-VPC interconnection.
Routing gRPC Service Requests Using a Dedicated Gateway
When you use a gRPC service, you can create an API in APIG to route requests for the service.
Forwarding WebSocket Service Requests Using a Dedicated Gateway
You can create WebSocket APIs in the same way as you create HTTP APIs. WebSocket is a protocol for full-duplex communication over a single TCP connection.
HTTP-to-HTTPS Auto Redirection with a Dedicated Gateway
HTTP APIs are insecure in transmission and authentication. You can upgrade them for access over HTTPS while ensuring HTTP compatibility.
Calling Different Backend Services Using a Dedicated Gateway
APIG allows you to define multiple backend policies and forward API requests to different backends based on these different policies. For example, to distinguish special calls from regular calls, you can define a policy backend that uses frontend custom authentication parameters.
Configuring a FunctionGraph Backend for a Dedicated Gateway
Create a FunctionGraph function and use it as an API backend for seamless integration.
Developing a Custom Authorizer with FunctionGraph
Custom authentication is implemented using the FunctionGraph service. You can create a FunctionGraph function so that APIG can invoke it to authenticate requests for your API.
Configuring Two-factor Authentication (App + Custom)
APIG allows you to configure a custom authorizer for two-factor authentication.
Configuring One-Way or Two-Way Authentication Between the Dedicated Gateway and Client
If the API frontend supports HTTPS, you need to add an SSL certificate for the independent domain name bound to the API group. An SSL certificate is used for data encryption and identity authentication. If an SSL certificate contains a CA certificate, client authentication (two-way authentication) is enabled by default. Or one-way authentication will be used.
Using Request Throttling 2.0 for Fine-grained Request Throttling
As users and their demands become more diversified, the traditional policies cannot meet the requirements for more refined rate limiting. To resolve this issue, APIG has launched request throttling 2.0, which is a type of plug-in policy. The 2.0 policies enable you to configure more refined throttling, for example, to throttle requests based on a certain request parameter or tenant.
Using the JWT Authentication Policy to Implement Identity Authentication and Key Rotation
You can use JWT authentication in APIG with tokens from header, query, or cookie. By configuring a JWKS_URI for remote public keys, you can enable seamless key rotation.
Using WAF to Protect APIG
To protect APIG and your backend servers from malicious attacks, deploy Web Application Firewall (WAF) between APIG and the external network.
APIG Security Best Practices
Improve the overall security capability of APIG.
