ConfigMaps
ConfigMaps are a type of resource used to store the configurations required by applications. They can store configuration data in key-value pairs or configuration files.
ConfigMaps allow you to decouple environment-specific configurations from container images, so that different environments can have their own unique configurations.
Creating a ConfigMap
In the following example, a ConfigMap named configmap-test is created. The ConfigMap configuration data is defined in the data field.
apiVersion: v1 kind: ConfigMap metadata: name: configmap-test data: # Configuration data property_1: Hello property_2: World
Referencing a ConfigMap in an Environment Variable
ConfigMaps are usually referenced as environment variables or as configuration files in volumes.
In the following example, property_1 of configmap-test is referenced as the environment variable EXAMPLE_PROPERTY_1. Once the container starts, EXAMPLE_PROPERTY_1 holds the value of property_1, Hello.
apiVersion: v1
kind: Pod
containers:
- image: nginx:alpine
resources:
limits:
cpu: 100m
memory: 200Mi
requests:
cpu: 100m
memory: 200Mi
env:
- name: EXAMPLE_PROPERTY_1
valueFrom:
configMapKeyRef: # Reference a ConfigMap.
key: property_1
imagePullSecrets:
- name: default-secret Referencing a ConfigMap in a Volume
Referencing a ConfigMap in a volume is when you save the data as configuration files in the volume. Each piece of data is saved as an individual file. The key is the file name, and the key value is the file content.
In the following example, a volume named vol-configmap is created, the ConfigMap named configmap-test is referenced in this volume, and the volume is mounted to the /tmp directory of the container. After the pod is created, there are two files property_1 and property_2 in this /tmp directory, and the key values are Hello and World, respectively.
apiVersion: v1
kind: Pod
containers:
resources:
limits:
cpu: 100m
memory: 200Mi
requests:
cpu: 100m
memory: 200Mi
volumeMounts:
- name: vol-configmap # Mount the volume vol-configmap.
mountPath: "/tmp"
imagePullSecrets:
volumes:
configMap: # Reference a ConfigMap.
name: configmap-test What is your overall rating for this page?
