Pods
Video Tutorial
Overview of Pods
Pods are the smallest unit that you can create or deploy in Kubernetes. Each pod comprises one or more containers, shared storage (volumes), a unique IP address, and container runtime policies.
Pods can be used in either of the following ways:
- A pod runs a single container. This is the most common scenario in Kubernetes. In this case, a pod can be thought of as a container, although Kubernetes manages the pod rather than the container itself.
- A pod runs multiple tightly coupled containers that need to share resources. In this case, the pod includes a main container and several sidecar containers, as shown in Figure 1. For example, the main container might be a web server providing file services from a fixed directory, while sidecar containers periodically download files to that directory.
In Kubernetes, you rarely create pods directly. Instead, controllers like Deployments and jobs create and manage them. These controllers typically use pod templates to create and manage pods, providing features like replica management, rolling upgrades, and self-healing.
Creating a Pod
Kubernetes resources can be described using YAML or JSON files. The following is an example YAML file that describes a pod named nginx. This pod contains a container named container-0 that uses the nginx:alpine image. The container requests 100 mCPU and 200 MiB of memory.
apiVersion: v1 # The Kubernetes API version
kind: Pod # The Kubernetes resource type
name: nginx # The pod name
spec: # The pod specification
containers:
- image: nginx:alpine # The image nginx:alpine
name: container-0 # The container name
resources: # Requested resources for the container
limits:
cpu: 100m
memory: 200Mi
requests:
cpu: 100m
memory: 200Mi
imagePullSecrets: # The secret used to pull the image, which must be default-secret on CCE
- name: default-secret The above example shows that a YAML file includes:
- metadata: information such as name, label, and namespace
- spec: the pod specification, including the container image and volumes used
When checking a Kubernetes resource, you will also find the status field. It shows the current status of the resource. This field is automatically managed by Kubernetes and does not need to be set during resource creation. This example covers the minimum required parameters. Others will be described later.
In the following command, -f indicates that the pod will be created from a file, and nginx.yaml is the name of the file.
$ kubectl create -f nginx.yaml pod/nginx created
After creating the pod, check the pod status.
$ kubectl get pods NAME READY STATUS RESTARTS AGE nginx 1/1 Running 0 40s
The command output shows that the nginx pod is in the Running state. The READY state of 1/1 indicates that the pod has one container and that the container is in the Ready state.
You can run kubectl get to retrieve information about a pod with different output formats. Use -o yaml to obtain the information in YAML format or -o json to obtain in JSON format.
$ kubectl get pod nginx -o yaml
You can also run kubectl describe to view pod details.
$ kubectl describe pod nginx
Before deleting a pod, Kubernetes terminates all of the containers within it by sending a SIGTERM signal to the main process of each container. It then waits for a grace period (30s by default) for the containers to stop gracefully. If a container does not stop within this period, Kubernetes will send a SIGKILL signal to forcefully terminate it.
There are many ways to delete a pod. For example, you can delete a pod by name using the following command:
$ kubectl delete po nginx pod "nginx" deleted
You can delete multiple pods at once:
$ kubectl delete po pod1 pod2
You can delete all pods at the same time:
$ kubectl delete po --all pod "nginx" deleted
Delete pods by label (see Labels):
$ kubectl delete po -l app=nginx pod "nginx" deleted
Environment Variables
You can use environment variables to configure the runtime environment of a container.
They add flexibility to application settings and allow you to customize settings when you create a container. These settings take effect when the container runs, eliminating the need to rebuild the container image.
The following shows an example, in which you only need to configure the environment variable spec.containers.env:
apiVersion: v1
kind: Pod
containers:
resources:
limits:
cpu: 100m
memory: 200Mi
requests:
cpu: 100m
memory: 200Mi
env: # The environment variable
- name: env_key
value: env_value
imagePullSecrets:
- name: default-secret Check the environment variables in the container. The value of the env_key environment variable is env_value.
$ kubectl exec -it nginx -- env PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin HOSTNAME=nginx TERM=xterm env_key=env_value
Environment variables can also be defined using ConfigMaps or secrets. For details, see Referencing a ConfigMap as an Environment Variable or Referencing a Secret as an Environment Variable.
Container Startup Commands
Starting a container involves initiating its main process. You need to make some preparations before starting a main process. For example, before running a MySQL server, you may need to configure or initialize the environment. These preparatory steps can be handled by defining the ENTRYPOINT or CMD in a Dockerfile during image creation. For example, configuring ENTRYPOINT ["top", "-b"] in a Dockerfile ensures that CCE automatically performs the necessary preparations during container startup.
FROM ubuntu ENTRYPOINT ["top", "-b"]
In practice, you can define the command and its arguments for a container in a pod by setting the containers.command field. This field is a list, where the first element is the command, and subsequent elements are arguments.
apiVersion: v1
kind: Pod
containers:
resources:
limits:
cpu: 100m
memory: 200Mi
requests:
cpu: 100m
memory: 200Mi
command: # The startup command
- top
- "-b"
imagePullSecrets:
- name: default-secret Container Lifecycle
Kubernetes provides lifecycle hooks that allow containers to run custom operations at specific points in their lifecycle. For example, you can create a hook to perform an operation before a container is stopped. The available lifecycle hooks are as follows:
- postStart: triggered immediately after a container starts
- preStop: triggered immediately before a container stops
To use these hooks, simply configure the lifecycle.postStart or lifecycle.preStop parameter for a pod. The following shows an example:
apiVersion: v1
kind: Pod
containers:
resources:
limits:
cpu: 100m
memory: 200Mi
requests:
cpu: 100m
memory: 200Mi
lifecycle:
postStart: # Post-start processing
exec:
command:
- "/postStart.sh"
preStop: # Pre-stop processing
exec:
command:
- "/preStop.sh"
imagePullSecrets:
- name: default-secret Feedback
