- What's New
- Function Overview
- Getting Started
User Guide
- CodeArts Pipeline Usage
- Enabling and Authorizing CodeArts Pipeline
- Accessing CodeArts Pipeline
- Creating a Pipeline
- Configuring a Pipeline
- Grouping Pipelines
- Executing a Pipeline
- Checking a Pipeline
- Configuring a Change-triggered Pipeline
- Managing Pipeline Extensions
- Creating Service Endpoints
- Checking Audit Logs
- Reference
- CodeArts Release User Guide
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Template Management
Pipeline Management
- Starting a Pipeline
- Obtaining Pipeline Statuses in Batches
- Obtaining Pipeline Status/Obtaining Pipeline Execution Details
- Obtaining Pipeline List/Pipeline Execution Status in a Project
- Deleting a Pipeline
- Querying Pipeline Details
- Editing a Pipeline
- Stopping a Pipeline
- Obtaining Pipeline Execution Records
- Creating a Pipeline With a Template
- Retrying a Pipeline
- Passing Manual Review
- Rejecting Manual Review
- Querying Pipeline Logs
- Obtaining the Pipeline Step Execution Output
- Querying Build Products on a Pipeline
- Group Management
- Rule Management
- Tenant-level Policy Management
- Project-level Policy Management
Extension Management
- Creating an Extension Version
- Creating an Extension Draft Version
- Creating a Publisher
- Updating an Extension Draft
- Publishing an Extension Draft
- Updating Basic Information of an Extension
- Binding an Extension to a Publisher
- Updating the Extension Icon
- Updating the Publisher Icon
- Deleting an Extension Draft
- Querying the Publisher List
- Querying the Available Publisher
- Querying the Available Extension List
- Querying the Basic Extension List
- Querying the Available Extensions by Page
- Querying the Extension List
- Querying Extension Indicator Configuration
- Query Extension Input Configuration
- Query Extension Output Configuration
- Querying All Versions of an Extension
- Querying Extension Version Details
- Querying the Extension Version
- Deleting a Publisher
- Querying Publisher Details
- Creating a Basic Extension
- Updating a Basic Extension
- Deleting a Basic Extension
- Uploading a Basic Extension
- Querying the Basic Extension Details
- Template Management (Old Version, Unavailable Soon)
Pipeline Management (Old Version, Unavailable Soon)
- Quickly Creating a Pipeline and Jobs with a Template
- Checking the Pipeline Creation Status
- Obtaining the Pipeline List
- Obtaining the Pipeline Status
- Obtaining the Pipeline Execution Status in a Project
- Application Examples
- Appendixes
- Change History
- Functions
Troubleshooting
- Pipeline Fails to Run Because Repository Not Found
- Pipeline Fails to Run Because the Test Suite Is Already in Progress
- Pipeline Fails to Run Because Job Not Found
- Pipeline Is Not Triggered at a Specified Time
- Execution Button Is Unavailable
- Inappropriate Reviewer Configured for the Manual Review Job
- Subpipeline Not Found
- Change-triggered Pipeline Fails to Run and an Error Message Is Returned: "authentication required"
- Pipeline Fails to Run Because Deployment Policy Not Found
- Videos
Authentication
Requests for calling an API can be authenticated using either of the following methods:
- Token-based authentication: Requests are authenticated using a token.
- AK/SK-based authentication: Requests are authenticated by encrypting the request body using an AK/SK pair.
Token-based Authentication
The validity period of a token is 24 hours. When using a token for authentication, cache it to prevent frequently calling the Identity and Access Management (IAM) API for obtaining a user token.
A token specifies temporary permissions in a computer system. During API authentication using a token, the token is added to requests to get permissions for calling the API.
In Making an API Request, the process of calling the API used to obtain a user token is described.
When calling the API to obtain a user token, you must set auth.scope in the request body to project.
{ "auth": { "identity": { "methods": [ "password" ], "password": { "user": { "name": "username", "password": "********", "domain": { "name": "domainname" } } } }, "scope": { "project": { "name": "xxxxxxxx" } } } }
After a token is obtained, the X-Auth-Token header field must be added to requests to specify the token when other APIs are called. For example, if the token is ABCDEFJ...., X-Auth-Token: ABCDEFJ.... should be added to a request as follows:
GET https://iam.ap-southeast-3.myhuaweicloud.com/v3/auth/projects Content-Type: application/json X-Auth-Token: ABCDEFJ....
AK/SK-based Authentication
AK/SK-based authentication supports API requests with a body not larger than 12 MB. For API requests with a larger body, token-based authentication is recommended.
In AK/SK-based authentication, AK/SK is used to sign requests and the signature is then added to the requests for authentication.
- AK: access key ID. It is a unique ID associated with an SK. AK is used together with SK to sign requests.
- SK: secret access key. It is used together with an access key ID to identify a sender who initiates a request and to cryptographically sign requests, preventing the request from being modified.
In AK/SK-based authentication, you can use an AK/SK to sign requests based on the signature algorithm or use the signing SDK to sign requests. For details about how to sign requests and use the signing SDK, see AK/SK Signing and Authentication Guide.
The signing SDK is only used for signing requests and is different from the SDKs provided by services.
