Help Center/ FunctionGraph/ User Guide (Ally Region)/ FAQs/ Dependency Management FAQs/ How Do I Create a Dependency on the FunctionGraph Console?
Updated on 2026-01-09 GMT+08:00
- Log in to the FunctionGraph console, and choose Functions > Dependencies in the navigation pane.
- Click Create Dependency.
- Set the following parameters.
Table 1 Dependency configuration parameters Parameter
Name
Dependency name.
Code Entry Mode
Upload a ZIP file directly or through OBS.
- Upload ZIP file: Click Select File to upload a ZIP file.
- Upload from OBS: Specify an OBS link URL.
Runtime
Select a runtime.
Description of the dependency. This parameter is optional.
- Click OK. By default, a new dependency is version 1.
- Click the dependency name, and view all versions and related information on the displayed page. Each dependency can have multiple versions.
- To create a dependency version, click Create Version in the upper right corner of the page.
- To view the address of a version, click the version.
- To delete a version, click the delete icon in the same row.
Parent topic: Dependency Management FAQs
