Help Center/FunctionGraph/User Guide (Ally Region)/FAQs/General FAQs/What Should I Do If the os.system("command &") Execution Logs Are Not Collected?
Updated on 2026-01-09 GMT+08:00
Do not use os.system("command &"). The background command output will not be collected. To obtain the command output, use subprocess.Popen instead.
