Help Center/FunctionGraph/User Guide (Ally Region)/FAQs/External Resource Access FAQs/How Do I Configure External Network Access?
Updated on 2026-01-09 GMT+08:00
By default, functions deployed in a VPC are isolated from the Internet. If a function needs to access both internal and external networks, add a NAT gateway for the VPC.
- You have created a VPC and subnet according to section "Creating a VPC" in the Virtual Private Cloud User Guide.
- You have obtained an elastic IP address according to section "Assigning an EIP" in the Elastic IP User Guide.
Procedure of Creating a NAT Gateway
- Log in to the NAT Gateway console, and click Create NAT Gateway.
- On the displayed page, enter gateway information, select a VPC and subnet (for example, vpc-01), and confirm and submit the settings to create a NAT gateway. For details, see section "Creating a NAT Gateway".
- Click the NAT gateway name. On the details page that is displayed, click Add an SNAT Rule and click OK.
Parent topic:External Resource Access FAQs
