Updated on 2026-01-09 GMT+08:00
Function Execution FAQs
- How Long Does It Take to Execute a FunctionGraph Function?
- Which Steps Are Included in Function Execution?
- What If Function Instances Have Not Been Executed for a Long Time?
- How Can I Speed Up Initial Access to a Function?
- How Do I Know the Actual Memory Used for Function Execution?
- Why Is My First Request Slow?
- What Do I Do If an Error Occurs When Calling an API?
- How Do I Read the Request Header of a Function?
- How Do I Check the Memory Usage When Seeing "runtime memory limit exceeded"?
- How Do I Troubleshoot "CrashLoopBackOff"?
- After I Updated an Image with the Same Name, Reserved Instances Still Use the Old Image. What Can I Do?
Parent topic: FAQs
