Help Center/
FunctionGraph/
User Guide (Ally Region)/
FAQs/
External Resource Access FAQs/
How Does a Function Access Redis?
Updated on 2026-01-09 GMT+08:00
Perform the following operations:
- Check whether the Redis instance is deployed in a VPC.
- If the Redis instance is deployed in a VPC, configure the same VPC and subnet as the Redis instance for the function by referring to Configuring VPC Access.
- If the Redis instance is built on a public network, obtain its public IP address.
- Compile code for connecting a function to the Redis instance.
FunctionGraph has integrated third-party library redis-py in its Python 2.7 and Python 3.6 runtimes. Therefore, you do not need to download any other Redis libraries.
# -*- coding:utf-8 -*- import redis def handler (event, context): r = redis.StrictRedis(host="host_ip",password="passwd",port=6379) print(str(r.get("hostname"))) return "^_^"
- If the function fails to access to the Redis instance on a public network, perform the following operations:
- Modify the redis.conf file to allow access from any IP addresses.
- Set a password for accessing the Redis instance in the redis.conf file.
- Disable the firewall.
- If the function needs to access DCS APIs, create an agency and grant required permissions.
Parent topic: External Resource Access FAQs
