Help Center/ FunctionGraph/ User Guide (Ally Region)/ FAQs/ External Resource Access FAQs/ How Does a Function Access the MySQL Database?
Updated on 2026-01-09 GMT+08:00
Perform the following operations:
- Check whether the MySQL database is deployed in a VPC.
- Yes: Configure the same VPC and subnet as the MySQL database for the function by referring to Configuring VPC Access.
- No: See How Do I Configure External Network Access?
- Search for MySQL templates and select the one with the desired runtime. Set the parameters as required and click Create Function.
- After the MySQL function is created, choose Configuration > Environment Variables, click Edit Environment Variable. In the displayed dialog box, add environment variables and enable encryption as required, and click OK.
Parent topic: External Resource Access FAQs
