Cron Expression for a Function Timer Trigger
- @every format
The format is "@every N unit". N is a positive integer. unit can be ns, µs, ms, s, m, or h. An @every expression means invoking a function every N time units, as shown in Table 1.
- Standard format
The format is "seconds minutes hours day-of-month month day-of-week". day-of-week is optional. The fields must be separated from each other using a space. Table 2 describes the fields in a standard cron expression.
Table 2 Parameter description Parameter
Mandatory
Value Range
Special Characters Allowed
Seconds
Yes
0–59
Minutes
Yes
0–59
Hours
Yes
0–23
Day-of-month
Yes
1–31
Month
Yes
1–12 or Jan–Dec. The value is case-insensitive, as shown in Table 3.
Day-of-week
No
0–6 or Sun–Sat. The value is case-insensitive, as shown in Table 4. 0 means Sunday.
Table 3 Value description of the month field Month
Digit
Abbreviation
January
Jan
February
2
Feb
March
3
Mar
April
4
Apr
May
5
May
June
6
Jun
July
7
Jul
August
8
Aug
September
9
Sep
October
10
Oct
November
11
Nov
December
12
Dec
Table 4 Value description of the day-of-week field Day of Week
Digit
Abbreviation
Monday
Mon
Tuesday
2
Tue
Wednesday
3
Wed
Thursday
4
Thu
Friday
5
Fri
Saturday
6
Sat
Sunday
0
Sun
Table 5 describes the special characters that can be used in a cron expression.
Table 5 Special character description Special Character
Meaning
Remarks
Used to specify all values within a field.
* in the minutes field means every minute.
Used to specify multiple values, which can be discontinuous.
For example, "Jan,Apr,Jul,Oct" or "1,4,7,10" in the month field and "Sat,Sun" or "6,0" in the day-of-week field.
Used to specify a range.
For example, "0-3" in the minutes field.
Used to specify something in one of the two fields in which the character is allowed, but not the other.
You can specify something only in the day-of-month or day-of-week field. For example, if you want your function to be executed on a particular day (such as the 10th) of the month, but do not care what day of the week that is, then put "10" in the day-of-month field and "?" in the day-of-week field.
Used to specify increments. The character before the slash indicates when to start, and the one after the slash represents the increment.
For example, "1/3" in the minutes field means to trigger the function every 3 minutes starting from 00:01:00 of the hour.
Table 6 describes several example cron expressions.
Table 6 Example cron expressions Cron Expression
Meaning
0 15 2 * * ?
Executes a function at 02:15:00 every day.
0 30 8 ? * Mon-Fri
Executes a function at 08:30:00 every Monday through Friday.
0 45 7 1-3 * ?
Executes a function at 07:45:00 on the first three days of every month.
0 0/3 * ? * Mon,Wed,Fri,Sun
Executes a function every 3 minutes on every Monday, Wednesday, Friday, and Sunday.
0 0/3 9-18 ? * Mon-Fri
Executes a function every 3 minutes during 09:00–18:00 every Monday through Friday.
0 0/30 * * * ?
Executes a function every 30 minutes.
