Dependency Management
FunctionGraph enables you to manage dependencies in a unified manner. You can upload dependencies from a local path, or through OBS if they are too large, and specify names for them.
Creating a Dependency
- Log in to the FunctionGraph console, and choose Functions > Dependencies in the navigation pane.
- Click Create Dependency.
- Set the following parameters:
- Name: Enter a dependency name.
- Runtime: Select a runtime.
- Description: Enter a description for the dependency. This parameter is optional.
- Upload Mode: Upload a ZIP file or upload a file from OBS.
- Click OK.
Configuring Dependencies for a Function
- Log in to the FunctionGraph console, and choose Functions > Function List in the navigation pane.
- Click the name of the desired function.
- On the displayed function details page, click the Code tab, click Add in the Dependencies area.
- On the Select Dependency dialog box, select dependencies and click OK.
- You can add a maximum of 20 dependencies for a function.
- Except your private dependencies, FunctionGraph provides some common dependencies, which you can choose when creating a function.
- After configuring dependencies, click Save in the upper right corner.
Deleting a Dependency
- Click the name of the target dependency to go to the Versions page.
- Click the delete icon in the row of a version. Repeat this operation if the dependency has multiple versions.
Dependencies referenced by functions cannot be deleted.
FunctionGraph supports both standard and third-party libraries.
- Standard libraries
When using standard libraries, you can import them to your inline code or package and upload them to FunctionGraph.
- Supported non-standard libraries
FunctionGraph provides built-in third-party components listed in Table 1 and Table 2. You can import these libraries to your inline code in the same way as you import standard libraries.
Table 1 Third-party components integrated with the Node.js runtime Name
Usage
Version
q
Asynchronous method encapsulation
1.5.1
co
Asynchronous process control
4.6.0
lodash
Common tool and method library
4.17.10
esdk-obs-nodejs
OBS SDK
2.1.5
express
Simplified web-based application development framework
4.16.4
fgs-express
Provides a Node.js application framework for FunctionGraph and API Gateway to run serverless applications and REST APIs. This component provides an example of using the Express framework to build serverless web applications or services and RESTful APIs.
1.0.1
request
Simplifies HTTP invocation and supports HTTPS and redirection.
2.88.0
- Other third-party libraries (FunctionGraph has no built-in non-standard third-party libraries except those listed in the preceding table.)
To use functions of third-party libraries, package these libraries and upload them to a specified OBS bucket, and paste the OBS link URL of these libraries when creating a function.
Importing Dependent Libraries
The code for processing images is as follows:
# -*- coding: utf-8 -*-
from PIL import Image, ImageEnhance
from com.obs.client.obs_client import ObsClient
import sys
import os
current_file_path = os.path.dirname(os.path.realpath(__file__))
# append current path to search paths, so that we can import some third party libraries.
sys.path.append(current_file_path)
region = '******'
obs_server = 'obs.xxxxxxcloud.com'
def newObsClient(context):
ak = context.getAccessKey()
sk = context.getSecretKey()
return ObsClient(access_key_id=ak, secret_access_key=sk, server=obs_server,
path_style=True, region=region, ssl_verify=False, max_retry_count=5, timeout=20)
def downloadFile(obsClient, bucket, objName, localFile):
resp = obsClient.getObject(bucket, objName, localFile)
if resp.status < 300:
print 'download file', file, 'succeed'
else:
print('download failed, errorCode: %s, errorMessage: %s, requestId: %s' % resp.errorCode, resp.errorMessage,
resp.requestId)
def uploadFileToObs(client, bucket, objName, file):
resp = client.putFile(bucket, objName, file)
print 'upload file', file, 'succeed'
else:
print('upload failed, errorCode: %s, errorMessage: %s, requestId: %s' % resp.errorCode, resp.errorMessage,
resp.requestId)
def getObjInfoFromObsEvent(event):
s3 = event['Records'][0]['s3']
eventName = event['Records'][0]['eventName']
bucket = s3['bucket']['name']
objName = s3['object']['key']
print "*** obsEventName: %s, srcBucketName: %s, objName: %s", eventName, bucket, objName
return bucket, objName
def set_opacity(im, opacity):
"""Set the transparency."""
if im.mode != "RGBA":
im = im.convert('RGBA')
else:
im = im.copy()
alpha = im.split()[3]
alpha = ImageEnhance.Brightness(alpha).enhance(opacity)
im.putalpha(alpha)
return im
def watermark(im, mark, opacity=0.6):
"""Add a watermark."""
try:
if opacity < 1:
mark = set_opacity(mark, opacity)
if im.mode != 'RGBA':
if im.size[0] < mark.size[0] or im.size[1] < mark.size[1]:
print "The mark image size is larger size than original image file."
return False
x = (im.size[0] - mark.size[0]) / 2
y = (im.size[1] - mark.size[1]) / 2
layer = Image.new('RGBA', im.size, )
layer.paste(mark, (x, y))
return Image.composite(layer, im, layer)
except Exception as e:
print ">>>>>>>>>>> WaterMark EXCEPTION: " + str(e)
return False
def watermark_image(localFile, fileName):
im = Image.open(localFile)
watermark_image_path = os.path.join(current_file_path, "watermark.png")
mark = Image.open(watermark_image_path)
out = watermark(im, mark)
print "**********finish water mark"
name = fileName.split('.')
outFileName = name[0] + '-watermark.' + name[1]
outFilePath = "/tmp/" + outFileName
if out:
out = out.convert('RGB')
out.save(outFilePath)
else:
print "Sorry, Save watermarked file Failed."
return outFileName, outFilePath
def handler(event, context):
srcBucket, srcObjName = getObjInfoFromObsEvent(event)
outputBucket = context.getUserData('obs_output_bucket')
client = newObsClient(context)
# download file uploaded by user from obs
localFile = "/tmp/" + srcObjName
downloadFile(client, srcBucket, srcObjName, localFile)
outFileName, outFile = watermark_image(localFile, srcObjName)
# Upload converted files to a new OBS bucket.
uploadFileToObs(client, outputBucket, outFileName, outFile)
return 'OK' For standard libraries and supported non-standard libraries, you can directly use them in your function.
For non-standard third-party libraries that are not provided by FunctionGraph, you can use them by performing the following steps:
- Package the dependent libraries into a ZIP file, upload the ZIP file to an OBS bucket, and obtain the OBS link URL.
- Set the dependency name and runtime, specify the OBS link URL, and click OK.
- On the function details page, click the Code tab, click Add, select the dependency created in 4, and click OK.
- Click Save.
Each dependency package cannot contain a file with the same name as a code file. Otherwise, the two files may be incorrectly merged or overwritten. For example, if dependency package depends.zip contains a file named index.py, the handler of a function cannot be set to index.handler. Otherwise, a code file also named index.py will be generated.
