Help Center/ FunctionGraph/ User Guide (Ally Region)/ User Guide/ Getting Started/ Configuring Asynchronous Execution Notification
Updated on 2026-01-09 GMT+08:00
Overview
Functions can be invoked synchronously or asynchronously. In asynchronous mode, FunctionGraph sends a response immediately after persisting a request. The request result cannot be known in real time. To retry when an asynchronous request fails or obtain asynchronous processing results, configure asynchronous settings.
Applications Scenarios
  • Retry: By default, FunctionGraph does not retry if a function fails due to a code error. If your function needs retry, for example, if third-party services often fail to be invoked, configure retry to improve the success rate.
  • Result notifications: FunctionGraph automatically notifies downstream services of the asynchronous execution result of a function for further processing. For example, storing execution failure information in OBS for cause analysis, or pushing execution success information to DIS or triggering the function again.
  1. Set an agency that allows FunctionGraph to access the target service.
  2. To avoid cyclic invocation, do not set two functions as asynchronous execution targets of each other.
  1. Log in to the FunctionGraph console, and choose Functions > Function List in the navigation pane.
  2. Click the name of the created function.
  3. Choose Configuration > Configure Async Notification. On the displayed page, click Edit next to Asynchronous Notification Policy.
  4. Set the parameters based on Table 1.
    Table 1 Parameter description
    • Max. Retries: maximum number of retries when asynchronous invocation fails. Value range: 0–3. Default value: 1.
    • Max. Validity Period (s): maximum lifetime of a message in seconds. Value range: 1–86,400.
    Success Notification
    Target Service: to which a notification will be sent if a function is executed successfully.
    1. FunctionGraph
    2. OBS
    Failure Notification
    Target Service: to which a notification will be sent if a function fails to be executed.
    1. FunctionGraph
    2. OBS
  5. Click OK to complete the configuration.
Configuration Description
For details about how to set the target for asynchronous invocation, see Table 2. The following shows an example:
        "timestamp": "2020-08-20T12:00:00.000Z",
	"request_context": {
	        "request_id": "1167bf8c-87b0-43ab-8f5f-26b16c64f252",
	        "function_urn": "urn:fss:xx-xxxx-x:xxxxxxx:function:xxxx:xxxx:latest",
	        "condition": "",
	        "approximate_invoke_count": 0
	    "request_payload": "",
	    "response_context": {
	        "status_code": 200,
	        "function_error": ""
	 "response_payload": "hello world!"
Table 2 Parameter description
timestamp
Time when the invocation starts.
request_context
Request context.
request_context.request_id
ID of an asynchronous invocation request.
request_context. function_urn
URN of the function that is to be executed asynchronously.
request_context.condition
Invocation error type.
request_context. approximate_invoke_count
Number of asynchronous invocation times. If the value is greater than 1, function execution has been retried.
request_payload
Original request payload.
response_context
Response context.
response_context.statusCode
Code returned after function invocation. If the code is not 200, a system error occurred.
response_context.function_error
Invocation error information.
response_payload
Payload returned after function execution.
