Version and Alias Management
Managing Versions
After a function is created, the default version is latest. Each function has the latest version. After the function code is published, you can modify the version configuration as required.
Publishing a Version
- Log in to the FunctionGraph console, and choose Functions > Function List in the navigation pane.
- Click the name of the desired function.
- Select the latest version, click the Version tab, and click Publish New Version.
- Set the following information.
- Version: Enter a version number. If no version number is specified, the system automatically generates a version number based on the current date, for example, v20170819-190658.
- Description: Enter a description for the version. This parameter is optional.
- Click OK. The system automatically publishes a version. Then you will be redirected to the new version.
- You can publish up to 20 versions for a function.
- For a function whose latest version has been configured with reserved instances, the function configuration can be modified. By default, non-latest versions do not have reserved instances.
- No disk is attached to a new version created based on latest. Environment variables cannot be set if no trigger has been bound to the version.
Deleting a Version
- On the Version tab page of the latest version, select the version to delete.
- The latest version of a function cannot be deleted.
- If a function version associated with aliases is deleted, the aliases will also be deleted.
- Click OK to delete the version.
Deleting a version will permanently delete the associated code, configuration, alias, and event source mapping, but will not delete logs. Deleted versions cannot be recovered. Exercise caution when performing this operation.
