Using an LTS Trigger
For details about the LTS event source, see Supported Event Sources.
- You have created a function on FunctionGraph. For details, see Creating and Initializing a Function.
- You have created a log group, for example, LogGroup1. For details, see section "Creating a Log Group" in the Log Tank Service User Guide.
- You have created a log stream, for example, LogStream1. For details, see section "Creating a Log Stream" in the Log Tank Service User Guide.
Creating an LTS Trigger
- Log in to the FunctionGraph console, and choose Functions > Function List in the navigation pane.
- Click the HelloWorld function.
- Choose Configuration > Triggers and click Create Trigger.
- Set the following parameters:
- Trigger Type: Select Log Tank Service (LTS).
- Log Group: Select a log group, for example, LogGroup1.
- Log Stream: Select a log stream, for example, LogStream1.
- Click OK.
Configuring an LTS Event to Trigger the Function
- On the function details page, click the Code tab and select Configure Test Event.
- Set the parameters described in Table 1 and click Save.
Table 1 Test event information Parameter
You can choose to create a test event or edit an existing one.
Use the default option Create new test event.
Event Template
Select Log Tank Service (LTS) and use the built-in LTS event template.
Event Name
The event name can contain 1 to 25 characters and must start with a letter and end with a letter or digit. Only letters, digits, underscores (_), and hyphens (-) are allowed. For example, lts-123test.
Event data
The system automatically loads the built-in LTS event template, which is used in this example without modifications.
The event template is as follows:
{ "lts": { "data": "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" } } - Click Test. The function test result is displayed.
