Using an SMN Trigger
For details about the SMN event source, see Supported Event Sources.
- You have created an SMN topic, for example, smn-test. For details, see section "Creating a Topic" in the Simple Message Notification User Guide.
- You have created a function on FunctionGraph. For details, see Creating and Initializing a Function.
Creating an SMN Trigger
- Log in to the FunctionGraph console, and choose Functions > Function List in the navigation pane.
- Click the HelloWorld function.
- On the HelloWorld function details page, choose Configuration > Triggers.
- Click Create Trigger.
- Set the following parameters:
- Trigger Type: Select Simple Message Notification (SMN).
- Topic Name: Select a topic, for example, smn-test.
- Click OK.
After the SMN trigger is created, a subscription is generated for the corresponding topic on the SMN console.
Publishing a Message to Trigger the Function
On the SMN console, publish a message to the smn-test topic. For details, see section "Publishing a Text Message" in the Simple Message Notification User Guide.
Table 1 describes the parameters required for publishing a message. After the message is published, the function is automatically triggered.
Viewing the Execution Result
- On the function details page, choose Monitoring > Logs to view function logs.
