Application Scenarios
FunctionGraph is suitable for various scenarios, such as real-time file processing, real-time data stream processing, web & mobile application backends, and artificial intelligence (AI) application.
Real-time File Processing
Uploading files from a client to OBS triggers functions that create image thumbnails in real time, convert video formats, aggregate and filter data files, or implement other file operations.
Advantages:
- FunctionGraph automatically scales out resources to run more function instances as the number of requests increases.
- Files are uploaded to OBS to trigger file processing functions.
Web & Mobile Backends
Interconnect FunctionGraph with other cloud services or your VMs to quickly build highly available and scalable web & mobile backends.
Advantages:
- FunctionGraph ensures high reliability of website data using OBS and CloudTable, and high-availability of website logic using API Gateway.
Artificial Intelligence
Integrate FunctionGraph with EI services for text recognition and illicit image identification.
Advantages:
- FunctionGraph works with EI services for text recognition and content moderation to suit a wide range of scenarios – make adjustments whenever you need as demands change.
- You only need to apply for related services and write service code without having to provision or manage servers.
