Related Services
Table 1 describes the cloud services that have been interconnected with FunctionGraph.
| Service | Function |
| SMN | FunctionGraph functions are constructed to process SMN notifications. For details, see . |
| API Gateway | FunctionGraph functions are invoked over HTTPS by defining REST APIs with specified backend services. |
| OBS | FunctionGraph functions are created to process OBS bucket events, such as object creation or deletion events. For example, when an image is uploaded to the specified bucket, OBS invokes the function to read the image and create a thumbnail. |
| LTS | FunctionGraph functions are built to process logs subscribed to in LTS. When LTS collects subscribed logs, the function is triggered to process or analyze the logs or to load the logs to other systems. |
| CTS | FunctionGraph functions are defined to analyze and process key information in logs according to the event notifications of specified service type and operations configured in CTS.
| DDS | DDS triggers trigger FunctionGraph functions upon a table change in the database. |
| Cloud Eye | FunctionGraph is interconnected with Cloud Eye to report monitoring metrics, allowing you to view function metrics and alarm messages through Cloud Eye. |
| VPC | Functions can be configured to access resources in Virtual Private Clouds (VPCs) or to access the Internet through source network address translation (SNAT) by binding elastic IP addresses. |
| Operation | Resource Type | Trace Name |
| Creating a function | Function | CreateFunction |
| Deleting a function | Function | DeleteFunction |
| Modifying function information | Function | ModifyFunctionMetadata |
| Publishing a function version | Function version | PublishFunctionVersion |
| Deleting a function alias | Function version alias | DeleteVersionAlias |
| Deleting a function trigger | Trigger | DeleteTrigger |
| Creating a function trigger | Trigger | CreateTrigger |
| Disabling a function trigger | Trigger | DisabledTrigger |
| Enabling a function trigger | Trigger | enabledTrigger |
