Help Center/FunctionGraph/User Guide (Ally Region)/User Guide/Overview/Relationship Between FunctionGraph and Other Services
Updated on 2026-01-09 GMT+08:00
FunctionGraph is interconnected with other cloud services to implement different functions.
Cloud Eye is a multi-dimensional monitoring platform that monitors resources such as Elastic Cloud Servers (ECSs) and bandwidth. With Cloud Eye, you can track the resource usage and status of services running on the cloud platform, receive alarm notifications about errors, and react to changes immediately to keep your services running smoothly.
FunctionGraph is interconnected with Cloud Eye to monitor the execution of functions and workflows in real time.
CTS
CTS records the operations performed on the resources under your account. The operation records can help you perform security analysis, track resource changes, and locate faults. To store operation records for a longer time, subscribe to OBS and synchronize the records to it in real time.
  • FunctionGraph operations that can be recorded by CTS
    With CTS, you can record operations associated with FunctionGraph for later query, audit, and backtrack. Table 1 lists the FunctionGraph operations that can be recorded by CTS.
    Table 1 FunctionGraph operations
    Operation
    Resource Type
    Event Name
    Creating a function
    Function
    CreateFunction
    Deleting a function
    Function
    DeleteFunction
    Modifying function information
    Function
    ModifyFunctionMetadata
    Publishing a function version
    Function version
    PublishFunctionVersion
    Deleting a function version alias
    Function version alias
    DeleteVersionAlias
    Deleting a function trigger
    Trigger
    DeleteTrigger
    Creating a function trigger
    Trigger
    CreateTrigger
    Disabling a function trigger
    Trigger
    DisabledTrigger
    Enabling a function trigger
    Trigger
    enabledTrigger
    Executing a function
    Function instance
    invokeFunction
  • Auditing logs
    After CTS is enabled, the system starts recording operations on cloud resources. The CTS console stores operation records of the last seven days. For details, see section "Querying Real-Time Traces" in the Cloud Trace Service User Guide.
