How Do I Update My Security Score?
SecMaster checks your asset health in real time, evaluates the overall security posture, and gives a security score. A security score helps you quickly understand the overall status of unprocessed risks to your assets.
After asset security risks are fixed, manually ignore or handle alerts and update the alert status in the alert list. The risk severity can be down to a proper level accordingly. Your security score will be updated after you refresh the alert status and check your environment again.
Updating the Security Score
- Click
in the upper part of the page and choose Security > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
- In the navigation pane on the left, choose . On the baseline check page displayed, handle the baseline check items that fail the check.
- In the navigation pane on the left, choose Risk Prevention > Vulnerabilities. On the vulnerability management page displayed, handle the vulnerabilities.
- In the navigation pane on the left, choose . On the displayed page, handle the alert.
- After handling unsafe settings, vulnerabilities, or alerts, go back to the Check Again. After the check, the security score will be updated.
page and click
It takes some time for a check to finish. You can refresh the page to get the new security score five minutes after you start the recheck.
