Can I Unsubscribe from SecMaster?
If you no longer need SecMaster, you can unsubscribe from it or cancel it in just a few clicks.
- Pay-per-use billing mode: pay for what you use by the hour. This mode allows you to enable or disable resources at any time. One-click resource cancellation is also supported.
For ECSs and VPC endpoints you create for collecting log data, you need to manually release them after unsubscribing from SecMaster, or those resources will continue to be billed..
Limitations and Constraints
- In the pay-per-use professional edition, when you unsubscribe from or cancel the asset quota of the professional edition, the value-added package is also unsubscribed or canceled.
- After unsubscribing from SecMaster, you need to manually release the following resources:
- If you have enabled data collection, you need to manually release the ECSs used for data collection. For details, see Elastic Cloud Server User Guide.
- If you have enabled data collection, you need to manually release the VPCEP nodes you used to connect and manage the collection nodes. For details, see VPC Endpoint User Guide.
Canceling Pay-per-Use SecMaster Resources
- Click
in the upper part of the page and choose Security > SecMaster.
- Click Professional in the upper right corner. The edition management window is displayed.
- In the row of the SecMaster edition purchased in pay-per-use billing mode, click Cancel to release the purchased SecMaster resources.
Go to the edition management window and verify that the subscription to resources billed on a pay-per-use basis is canceled.
Unsubscribing from a Value-Added Package
- Click
- Click Professional in the upper right corner. A window for you to manage SecMaster assets will be displayed.
- Click Cancel to release the pay-per-use asset quota. Go to the edition management window and verify that subscriptions to pay-per-use resources have been canceled.
