Starting an Immediate Baseline Check
To learn about the latest status of the cloud service baseline configurations, execute or let SecMaster execute a check plan. Then you can view which configurations are unsafe in the check results. The baseline inspection supports periodic and immediate checks.
- Periodic check: SecMaster periodically executes the default check plan or the check plans you configure.
- Immediate check: You can start check items in all security standards or a specific check plan anytime.
This topic describes how to start an immediate baseline inspection. You can select the following check types:
- Immediate Check on All Compliance Packs: Check the compliance of all automatic check items in in-use compliance packs.
- Starting a Check Based on a Check Plan: Check the compliance of the check items in the compliance pack configured in a selected check plan.
- Immediate Checks on Certain Check Items: check the selected check items.
Limitations and Constraints
- An immediate check task can be executed only once within 10 minutes.
- A periodic check can be manually started only once within 10 minutes.
This part describes how to start an immediate check for automatic check items in in-use compliance packs.
- Click
in the upper part of the page and choose Security > SecMaster. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace. Figure 1 Workspace management page
- In the navigation pane on the left, choose Risk Prevention > Baseline Inspection. Figure 2 Accessing the check result page
- On the Check Result tab, click Check Now. In the dialog box displayed, click OK.
Refresh the page. To check whether the displayed result is the latest, click View Details in the Operation column and check the time in Latest Check.
This part describes how to immediately execute a check plan. Once a check plan is kicked off, SecMaster immediately executes each check item included in compliance packs in the check plan.
- Click
in the upper part of the page and choose Security > SecMaster. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace. Figure 3 Workspace management page
- In the navigation pane on the left, choose . On the displayed page, click the Security Standards tab. Then, click the Check Plan tab. Figure 4 Check Plan tab
- In a check plan box, click Check Now.
SecMaster immediately executes the selected baseline check plan.
This part describes how to start an immediate check on certain check items.
- Click
in the upper part of the page and choose Security > SecMaster. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace. Figure 5 Workspace management page
- In the navigation pane on the left, choose Risk Prevention > Baseline Inspection. Figure 6 Accessing the check result page
- Check one or more check items immediately.
- Check on a single check item
- In the check item list in the lower part of the Check Result tab, locate the target automatic check item and click Check Now in the Operation column.
Refresh the page and check the details next to Last checked and ensure that the latest scan result is displayed.
- Checks on some check items
- In the check item list in the lower part of the check result tab, select multiple auto check items and click Check Now in the upper left corner above the check item list.
