- What's New
- Function Overview
Billing
- Billing Overview
- Billing Modes
- Billing Items
- Billing Examples
- Changing the Billing Mode
- Renewing Your Subscription
- Bills
- About Arrears
- Billing Termination
- Cost Management
Billing FAQs
- How Is SecMaster Billed?
- Can I Use SecMaster for Free?
- How Do I Change or Disable Auto Renewal for SecMaster?
- Will SecMaster Be Billed After It Expires?
- How Do I Renew SecMaster?
- Where Can I Unsubscribe from SecMaster?
- Where Can I View the Remaining Quotas of Security Data Collection and Security Data Packages?
- Can I Change the Billing Mode for SecMaster?
- Getting Started
User Guide
- Buying SecMaster
- Authorizing SecMaster
- Checking Security Overview
- Workspaces
- Viewing Purchased Resources
Security Governance
- Security Governance Overview
- Security Compliance Pack Description
- Authorizing SecMaster to Access Cloud Service Resources
- Subscribing to or Unsubscribing from a Compliance Pack
- Starting a Self-Assessment
- Viewing Security Compliance Overview
- Viewing Evaluation Results
- Viewing Policy Scanning Results
- Downloading a Compliance Report
- Security Situation
- Resource Manager
- Risk Prevention
- Threats
- Security Orchestration
Playbook Overview
- Ransomware Incident Response Solution
- Attack Link Analysis Alert Notification
- HSS Isolation and Killing of Malware
- Automatic Renaming of Alert Names
- Auto High-Risk Vulnerability Notification
- Automatic Notification of High-Risk Alerts
- Auto Blocking for High-risk Alerts
- Real-time Notification of Critical Organization and Management Operations
Settings
- Data Integration
Log Data Collection
- Data Collection Overview
- Data Collection Process
- Adding a Node
- Configuring a Component
- Adding a Connection
- Creating and Editing a Parser
- Adding and Editing a Collection Channel
- Verifying Log Collection
- Managing Connections
- Managing Parsers
- Managing Collection Channels
- Viewing Collection Nodes
- Managing Nodes and Components
- Partitioning a Disk
- Logstash Configuration Description
- Connector Rules
- Parser Rules
- Upgrading the Component Controller
- Customizing Directories
- Permissions Management
- Key Operations Recorded by CTS
Best Practices
Log Access and Transfer Operation Guide
- Solution Overview
- Resource Planning
- Process Flow
- (Optional) Step 1: Buy an ECS
- (Optional) Step 2: Buy a Data Disk
- (Optional) Step 3: Attach a Data Disk
- Step 4: Create a Non-administrator IAM User
- Step 5: Configure Network Connection
- Step 6: Install the Component Controller (isap-agent)
- Step 7: Install the Log Collection Component (Logstash)
- (Optional) Step 8: Creating a Log Storage Pipeline
- Step 9: Configure a Connector
- (Optional) Step 10: Configure a Log Parser
- Step 11: Configure a Log Collection Channel
- Step 12: Verify Log Access and Transfer
- Credential Leakage Response Solution
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Alert Management
- Incident Management
- Indicator Management
- Playbook Management
- Alert Rule Management
- Playbook Version Management
- Playbook Rule Management
- Playbook Instance Management
- Playbook Approval Management
- Playbook Action Management
- Incident Relationship Management
- Data Class Management
- Workflow Management
- Data Space Management
- Pipelines
- Workspace Management
- Metering and Billing
- Metric Query
- Baseline Inspection
- Appendix
- FAQs
More Documents
- Buying SecMaster
- Viewing Security Overview
- Workspaces
Security Governance
- Resource Manager
- Risk Prevention
- Threat Operations
Settings
- Data Integration
Log Data Collection
- Adding a Node
- Managing Parsers
- Connector Rules
- Parser Rules
- FAQs
- Change History
- Security Overview
- Workspaces
- Resource Manager
Risk Prevention
Baseline Inspection
- Baseline Inspection Overview
- Creating a Custom Check Plan
- Starting an Immediate Baseline Check
- Viewing Check Results
- Handling Check Results
- Viewing Compliance Packs
- Creating a Custom Compliance Pack
- Importing and Exporting a Compliance Pack
- Viewing Check Items
- Creating a Custom Check Item
- Importing and Exporting Check Items
- Vulnerability Management
- Policy Management
Baseline Inspection
Threat Operations
- Alert Management
- Intelligent Modeling
- Security Analysis
- Data Delivery
- Security Orchestration Overview
- Built-in Playbooks
- Security Orchestration Process
- (Optional) Configuring and Enabling a Workflow
- Configuring and Enabling a Playbook
- Operation Object Management
- Playbook Orchestration Management
- Layout Management
- Plug-in Management
- Settings
Product Consulting
- Why Is There No Attack Data or Only A Small Amount of Attack Data?
- Where Does SecMaster Obtain Its Data From?
- What Are the Dependencies and Differences Between SecMaster and Other Security Services?
- What Are the Differences Between SecMaster and HSS?
- How Do I Update My Security Score?
- How Do I Handle a Brute-force Attack?
- Issues About Data Synchronization and Data Consistency
- About Data Collection Faults
Product Consulting
- Change History
On this page
Help Center/
SecMaster/
User Guide (ME-Abu Dhabi Region)/
Buying SecMaster/
Unsubscribing from SecMaster
If you no longer need SecMaster, you can unsubscribe from it or cancel it in just a few clicks.
Limitations and Constraints
- In the pay-per-use professional edition, when you unsubscribe from or cancel the asset quota of the professional edition, the value-added package is also unsubscribed or canceled.
- After unsubscribing from SecMaster, you need to manually release the following resources:
- If you have enabled data collection, you need to manually release the ECSs used for data collection. For details, see Elastic Cloud Server User Guide.
- If you have enabled data collection, you need to manually release the VPCEP nodes you used to connect and manage the collection nodes. For details, see VPC Endpoint User Guide.
Canceling Pay-per-Use SecMaster Resources
- Click
in the upper part of the page and choose Security > SecMaster.
- Click Professional in the upper right corner. The edition management window is displayed.
- In the row of the SecMaster edition purchased in pay-per-use billing mode, click Cancel to release the purchased SecMaster resources.
Go to the edition management window and verify that the subscription to resources billed on a pay-per-use basis is canceled.
Unsubscribing from a Plus Features
- Click
- Click Professional in the upper right corner. A window for you to manage SecMaster assets will be displayed.
- Click Cancel to release the pay-per-use asset quota. Go to the edition management window and verify that the pay-per-use asset quota is canceled.
Parent topic: Buying SecMaster
