Updated on 2025-01-20 GMT+08:00
Baseline Inspection Overview
SecMaster can scan cloud services for risks in key configuration items, report scan results by category, generate alerts for incidents, and provide hardening suggestions and guidelines.
Baseline Check Methods
  • Automated baseline checks
    By default, SecMaster performs a check every three days. From 00:00 to 06:00, SecMaster checks all assets in the current region under your account based on compliance pack Cloud Security Compliance Check 1.0. The default check plan can be enabled or disabled only. No changes on its compliance packs or execution time can be made.
  • Scheduled custom baseline checks
    You can customize the automatic check period, check time, and check scope. For details, see Performing a Scheduled Baseline Check.
  • Immediate baseline checks
    • You can start all compliance packs in use to detect violations against automatic check items.
    • You can start a check plan to detect violations against check items in the compliance pack configured in the check plan.
    • You can select one or more check items and start them at once.
  • Manual baseline checks
    There are some manual check items included in baseline inspection. After you finish a manual check, report the check results to SecMaster. The pass rate is calculated based on results from both manual and automatic checks. For automatic check items, you can manually start specific checks.
    For details about manual checks, see Performing a Manual Baseline Check.
Process
The process of baseline inspection is as follows.
Table 1 Process
No.
Operation
Conducting a Scheduled Baseline Inspection
SecMaster uses the default check plan to check all assets.
  • Default plan: SecMaster checks your assets under your account in the current region every three days from 00:00 to 06:00.
  • Custom plans: SecMaster performs baseline inspections based on the compliance packs and time you specify in the custom check plans.
2
Starting an Immediate Baseline Check
The baseline inspection supports periodic and immediate checks.
  • Periodic check: The system automatically executes the default check plan or the check plans you configure.
  • Immediate check: You can add or modify a custom check plan and start the check plan immediately. In this way, you can check whether the servers have certain unsafe configurations in real time.
3
Viewing Baseline Inspection Results
You can view the baseline inspection results after each manual check or automated check. You can quickly learn affected assets and details about the baseline inspection items.
4
Handling Baseline Inspection Results
You can handle risky items based on the rectification suggestions.
