Updated on 2024-07-18 GMT+08:00
Baseline Inspection Overview
SecMaster can scan cloud services for risks in key configuration items, report scan results by category, generate alerts for incidents, and provide hardening suggestions and guidelines.
Baseline Check Methods
  • Automated baseline checks
    Every three days SecMaster checks your assets under your account in the current region from 00:00 to 06:00.
    You can specify a schedule and start time to let SecMaster perform baseline inspection. For details, see Creating a Custom Baseline Check Plan.
  • Manual baseline checks
    There are some manual check items included in baseline inspection. After you finish a manual check, report the check results to SecMaster. The pass rate is calculated based on results from both manual and automatic checks. For automatic check items, you can manually start specific checks.
    For details about manual checks, see Handling Manual Check Items.
Process
Table 1 Process
No.
Operation
(Optional) Creating a Custom Baseline Check Plan
SecMaster uses the default check plan to check all assets.
  • Default plan: SecMaster checks your assets under your account in the current region every three days from 00:00 to 06:00.
  • Custom plans: SecMaster performs baseline inspections based on the standards and time you specify in the custom check plans.
2
(Optional) Starting an Immediate Baseline Check
The baseline inspection supports periodic and immediate checks.
  • Periodic check: The system automatically executes the default check plan or the check plans you configure.
  • Immediate check: You can add or modify a custom check plan and start the check plan immediately. In this way, you can check whether the servers have certain unsafe configurations in real time.
3
Viewing Baseline Inspection Results
You can view the baseline inspection results, affected assets, and details about the baseline inspection items.
4
Handling Baseline Inspection Results
You can handle risky items based on the rectification suggestions.
