Managing Check Items
Updated on 2025-01-20 GMT+08:00
This topic describes how to manage check items, including Viewing Check Items, Creating a Custom Check Item, Importing Check Items, and Exporting Check Items.
Limitations and Constraints
  • For custom check items, SecMaster does not check them immediately after they are created. You need to perform an immediate check manually or check the compliance pack the check items associated with. Then, you can get their check results.
  • When you import check items, note the following restrictions:
    • Only .xlsx files can be imported.
    • Only one file can be imported at a time. Maximum file size: 100 records.
Viewing Check Items
  2. Click in the upper part of the page and choose Security > SecMaster.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the navigation pane on the left, choose Risk Prevention > Baseline Inspection. On the displayed page, click the Security Standards tab. Then, click the Check Item tab.
    Figure 2 Accessing the Check Item tab
  5. On the Check Item tab, view the information about existing check items. For details about the parameters, see Table 1.
    Table 1 Parameters for check items
    Check Items
    Total number of check items in the current workspace.
    Built-in Check Items
    The number of check items preconfigured in SecMaster.
    Custom Check Items
    The number of check items you create.
    Check items and details
    All check items and their basic information.
    • In the check item list, you can view the description, type, and number of compliance packs used for a check item. You can also edit or delete custom check items.
    • To display certain columns only, click the setting button in the upper right corner of the check item list and complete the settings (for example, whether to wrap lines and whether to fix the operation column).
    • To view details about a check item, click its name. The details page is displayed on the right.
      On the check item details page, you can view the description and compliance pack used for the check item.
    Figure 3 Workspace management page
    Figure 4 Accessing the Check Item tab
  5. Click Create Check Item in the upper left corner of the check item list.
  6. On the Create Check Item page, set check item parameters.
    Table 2 Parameters for creating check items
    Check Item
    Name you specify for the check item.
    Description you provide for the check item.
    Severity
    Select the severity of the check item.
    Action
    Select an action for the check item.
    • Executed by workflows: The check item is automatically executed through a workflow you specify, and the check result is reported by the workflow as well.
    • Executed manually: You will manually complete the check item offline.
    Select Workflow
    If Action for a check item is set to Executed by workflows, you need to select a workflow for the check item.
    If no appropriate workflows are available, click Create Workflow and create one on the workflow page.
    Manual Check Items
    If Action for a check item is set to Executed manually, SecMaster sets the check result options by default.
    Cloud Service
    Enter the information about the cloud service associated with the check item.
  7. Click OK.
    You can edit or delete custom check items you add as required.
    Figure 5 Workspace management page
    Figure 6 Accessing the Check Item tab
  5. In the upper left corner above the check item list, click Import.
  6. In the dialog box displayed, click Download Template and complete the template.
  7. In the displayed dialog box, click Add File and upload the completed template file.
  8. Click Import.
    Figure 7 Workspace management page
    Figure 8 Accessing the Check Item tab
  5. Select check items you want to export from the check item list and click Export in the upper left corner above the list.
  6. In the displayed dialog box, select the format and data columns you want.
  7. Click Export.
