Updated on 2025-01-20 GMT+08:00
Connector Rules
Source Connectors
SecMaster provides a wide range of source connectors for you to collect security data from your security products.
Table 1 Source connector types
Connector Type
In-use Logstash
TCP
tcp
This collector is used to receive TCP logs. For details about the configuration rules, see Table 2.
UDP
udp
This collector is used to receive UDP logs. For details about the configuration rules, see Table 3.
OBS
obs
This collector is used to obtain log data from an OBS bucket. For details about the configuration rules, see Table 4.
Kafka
kafka
This collector is used to obtain Kafka network log data. For details about the configuration rules, see Table 5.
pipe
This collector is used to transfer SecMaster data to you. For details about the configuration rules, see Table 6.
Elasticsearch
elasticsearch
This collector is used to read data from the Elasticsearch cluster. For details about the configuration rules, see Table 7.
Table 2 TCP connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
Port
port
number
1025
Yes
Port number of the collection node.
Codec
codec
string
plain
Yes
Encoding format
  • Plain: Reads the original content.
  • Json: Processes the content in JSON format.
Packet label
type
string
tcp
Yes
Used to label logs.
SSL_enable
ssl_enable
boolean
false
No
Whether to enable SSL verification.
SSL certificate
ssl_cert
file
null
No
Certificate.
SSL key
ssl_key
file
No
SSL key file.
SSL key
ssl_key_passphrase
string
No
SSL certificate key.
Table 3 UDP connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
Port
port
number
1025
Yes
Codec
codec
string
plain
Yes
Decoding type
Packet label
type
string
udp
No
Packet label, which is used for subsequent processing.
Queue size
queue_size
number
20000
No
Queue size.
Number of bytes in the receiving buffer
receive_buffer_bytes
number
20000
No
Buffer size
buffer_size
number
10000
No
Buffer size
Worker thread
workers
number
No
Number of worker threads
Table 4 OBS connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
region
region
string
Yes
region
Bucket
bucket
string
demo-obs-sec-mrd-datas
Yes
OBS bucket name
endpoint
endpoint
string
Yes
Endpoint address. Note that https must be added.
AK
ak
string
No
AK
SK
sk
string
No
SK
Prefix
prefix
string
/test
No
Prefix of the folder for log reads
Cache folder
temporary_directory
string
/temp
No
Cache folder for log reads
Packet label
type
string
No
Packet label
Memory path
sincedb_path
string
/opt/cloud/logstash/pipeline/file_name
No
Log read position. This parameter is used to prevent full-text traversal caused by restart.
Table 5 Kafka connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
Service address
bootstrap_servers
string
Yes
Service address
Topics
topics
array
logstash
Yes
Topics. Multiple topics can be consumed at the same time.
Consumer threads
consumer_threads
number
Yes
Consumer threads
Auto offset reset
auto_offset_reset
string
latest
No
Offset reset
  • Earliest: Read the earliest message.
  • Latest: Read the latest messages.
SSL certificate
ssl_truststore_location
file
No
SSL certificate
This parameter is mandatory when SSL is selected.
SSL key
ssl_truststore_password
string
No
SSL key
Security protocol
security_protocol
string
SASL_SSL
No
Security protocol
SASL connection configuration
sasl_jaas_config
string
No
Encrypted
is_pw_encrypted
string
false
No
Encrypted
SASL mechanism
sasl_mechanism
string
PLAIN
No
sasl_mechanism
Group ID
group_id
string
No
group_id
Set sasl_jaas_config based on the Kafka specifications. Example:
  • Plaintext connection configuration
    org.apache.kafka.common.security.plain.PlainLoginModule required username='kafka user'password='kafka password';
  • Ciphertext connection configuration
    org.apache.kafka.common.security.scram.ScramLoginModule required username='kafka user name'password='kafka password';
Table 6 Pipe connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
Type
type
string
Tenant
Yes
Type
Pipeline
pipeId
string
Yes
Pipeline ID
domain_name
domain_name
string
domain_name
Yes
Domain name of the user
User_name
user_name
string
user_name
Yes
Username of the user
Password
user_password
string
Yes
Subscription type
subscription_type
string
true
No
Subscription type
  • Shared: shared mode
  • Exclusive: exclusive mode
  • Failover: disaster recovery mode
Subscription Start
subscription_initial_position
string
true
No
Subscription Start
Table 7 Elasticsearch connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
Hosts
hosts
array
Yes
Host IP address
Index
index
string
Yes
Index
Retrieval statement
query
string
Yes
Retrieval statement
User_name
user
string
Yes
User_name
Password
user_password
string
Yes
Password
Queries
size
number
20
Yes
Queries
Scroll
scroll
string
5m
Yes
Volume
Docinfo
docinfo
boolean
true
Yes
Document
Is pw encrypted
is_pw_encrypted
boolean
true
Yes
Whether to enable encryption
ssl
boolean
true
No
Ssl
ca_file
file
No
Certificate file
SsL_certificate_verification
ssl_certificate_verification
boolean
true
No
SSL certificate verification
Destination Connectors
SecMaster provides a wide range of destination connectors for you to collect security data from your security products.
Table 8 Destination connectors
Connector Type
In-use Logstash
TCP
tcp
This collector is used to send TCP logs. For details about the configuration rules, see Table 9.
UDP
udp
This collector is used to send UD logs. For details about the configuration rules, see Table 10.
Kafka
kafka
This collector is used to write logs to Kafka message queues. For details about the configuration rules, see Table 11.
OBS
obs
This collector is used to write logs to OBS buckets. For details about the configuration rules, see Table 12.
SecMaster pipeline
pipe
This collector is used to write logs to the SecMaster pipeline. For details about the configuration rules, see Table 13.
Table 9 TCP connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
Port
port
number
1025
Yes
Port
Decoding type
codec
string
plain
Yes
Decoding type, which can be json_lines or Plain.
  • Json_lines: Processes the content in JSON format.
Hosts
host
string
192.168.0.66
Yes
Host address
Note: The network between the host and the node is normal.
SSL certificate
ssl_cert
file
No
SSL certificates
ssl_enable
boolean
false
No
Whether to enable SSL authentication
SSL key
ssl_key
file
No
SSL certificate file
SSL key
ssl_key_passphrase
string
No
SSL certificate key
Table 10 UDP connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
Hosts
host
string
Yes
Host IP address.
Port
port
number
1025
Yes
Port
Decoding type
codec
string
json_lines
Yes
Decoding type, which can be Json_lines or Plain.
Retry count
retry_count
number
3
No
Time of retry attempts
Retry backoff (ms)
retry_backoff_ms
number
200
No
Retry backoff (ms)
Table 11 Kafka connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
Service address
bootstrap_servers
string
Yes
Service address, for example, 192.168.21.21:9092,192.168.21.24:9999.
Topics
topic_id
string
logstash
Yes
Topics
Decoding type
codec
string
plain
Yes
Decoding type, which can be Json or Plain.
Maximum length of the request
max_request_size
number
10485760
Yes
SSL certificate
file
No
SSL certificates
SSL key
string
No
SSL key
Security protocol
security_protocol
string
PLAINTEXT
No
Security protocol
sasl_jaas_config
string
No
is_pw_encrypted
is_pw_encrypted
string
true
No
Whether to encrypt the value.
SASL mechanism
sasl_mechanism
string
PLAIN
No
sasl_mechanism
Set sasl_jaas_config based on the Kafka specifications. The following is an example:
Table 12 OBS connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
region
region
string
Yes
region
Bucket
bucket
string
Yes
Bucket name
endpoint
endpoint
string
Yes
endpoint
Cache folder
temporary_directory
string
/temp/logstash/
Yes
Cache path
Encoding type
codec
string
plain
No
Encoding format: plain or JSON
AK
ak
string
No
AK
SK
sk
string
No
SK
Prefix
prefix
string
test
No
Path prefix.
Encoding format
encoding
string
gzip
No
Encoding format: gzip or pure file
Memory path
sincedb_path
string
No
Table 13 Pipe connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
Type
type
string
Tenant
Yes
Type
Pipeline
pipeId
string
Yes
Pipeline
AK
ak
string
Yes
AK
This parameter is mandatory when the platform type is selected.
SK
sk
string
Yes
SK
domain_name
domain_name
string
domain_name
Yes
This parameter is mandatory when the tenant type is selected.
User_name
user_name
string
user_name
Yes
Password
user_password
string
Yes
Password of the user
Compression type
compression_type
string
NONE
No
Packet compression type
Block if the queue is full
block_if_queue_full
boolean
true
No
Whether to block the access if the queue is full.
Enable batch processing
enable_batching
boolean
true
No
Whether to enable batch processing.
