Upgrading the Component Controller
This topic describes how to upgrade the component controller from salt-minion to isap-agent for tenant-side data collection. salt-minion was used as component controller in earlier tenant-side data collection.
The upgrade does not affect the data plane.
- Click
in the upper part of the page and choose Security > SecMaster. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace. Figure 1 Workspace management page
- Deregister a node.
- In the navigation pane on the left, choose . On the displayed Nodes tab, locate the row that contains the target node and click Deregister in the Operation column.
The node is deregistered successfully, and its Health Status changes to Disconnected.
- Copy the script.
- Install the component controller.
- Use a remote management tool, such as Xftp, SecureFX, WinSCP, PuTTY, or Xshell, to log in to the disconnected ECS node.
- Run the command copied in 5.b as user root to install the Agent on the ECS. Figure 2 Installing the agent
- Enter the account username and password as prompted.
- If information similar to the following is displayed, the agent is successfully installed:
install isap-agent successfully
- Go to the SecMaster console and check the node status on the Nodes page under Settings.
- Delete the old management channel.
- Choose Settings > Components > Nodes and click Create. On the Create Node pane displayed, click Delete in the Operation column in the row of each the management.
