Help Center/ SecMaster/ User Guide (ME-Abu Dhabi Region)/ FAQs/ Data Collection/ Which Commands Are Commonly Used for the Component Controller?
Updated on 2025-01-20 GMT+08:00
Here are some commands you may need to troubleshoot the installation failure of the component controller isap-agent.
  • Restart
    sh /opt/cloud/isap-agent/action/agent_controller_linux.sh restart
    Note: This command will stop and then restart the isap-agent process. You can use command to restart isap-agent if isap-agent fails start or the process does not exist due to a node fault.
  • Start
    sh /opt/cloud/isap-agent/action/agent_controller_linux.sh start
    Note: You can use this command to start isap-agent if isap-agent breaks down but the automatic startup time for disaster recovery does not arrive.
  • Stop
    sh /opt/cloud/isap-agent/action/agent_controller_linux.sh stop
    You can use this command to stop isap-agent. This command will clear the scheduled automatic startup check settings to stop the isap-agent process.
  • Checking processes
    ps -ef|grep isap-agent
    You can use this command to check whether isap-agent is installed on the current host.
  • Checking logs
    tail -100f /opt/cloud/isap-agent/log/run.log
    You can use this command to query the latest 100 lines of logs of the isap-agent service to locate exceptions.
  • Disk partitions
    sh /opt/cloud/isap-agent/action/agent_controller_linux.sh partition
    When you install the collector on a node, you can use this command to partition disks you attach to the node.
