Managing Emergency Policies
This topic describes how to manage emergency policies, including Viewing Emergency Policies, Editing an Emergency Policy, and Deleting an Emergency Policy.
- Click
in the upper part of the page and choose Security > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
- In the navigation pane on the left, choose Risk Prevention > Security Policies. Then, go to the emergency policy page.
- On the Emergency Policies page, view emergency policy details.
Once an emergency policy is added, its blocked object type and blocked objects, such as IP addresses, IP address ranges, or IAM user names, cannot be modified.
- Click
Figure 2 Workspace management page
- On the emergency policy management page, locate the row that contains the policy you want to edit and click Edit in the Operation column.
- On the edit policy page, modify the policy information.
Table 2 Parameters for editing an emergency policy Parameter
Blocked Object Type
After an emergency policy is added, this parameter cannot be modified.
Block Object
Label
Label of the custom emergency policy.
Operation Connection
Select the operation connections for the policy.
Block Aging
The time the block action expires.
- If you select Yes, set the aging time of the policy. For example, if you set the aging time to 180 days, the policy is valid within 180 days after the setting. After 180 days, the IP address/range or the IAM user will not be blocked.
- If you select No, the policy is always valid and blocks the specified IP address/range or the IAM user.
Policy Description
Description of the custom policy.
- Click OK.
- Click
Figure 3 Workspace management page
- On the Emergency Policies tab, locate the row that contains the policy you want to delete and click Delete in the Operation column.
To delete multiple policies, select the target policies and click Batch Delete above the list.
- In the displayed confirmation dialog box, click Confirm.
