Overview
SecMaster provides policy management for you to manage and maintain tasks across accounts and resources. With this function, you can view all policies centrally, manage policies for seven defense lines manually, and query manual and automatic block records quickly.
- Adding an Emergency Policy: An emergency policy is used to quickly prevent attacks. You can select a block type based on the alert source to block attackers.
- Managing Emergency Policies: describes Viewing Emergency Policies, Editing an Emergency Policy, and Deleting an Emergency Policy.
- Batch Blocking and Canceling Batch Blocking of an IP Address or IP Address Range: describes how to block access from blacklisted IP addresses, IAM users, or IP address ranges. You can add an IP address, IAM user, or IP address range as blocked object for an emergency policy in several operation connections. If there is no need to block an IP address, IAM user, or IP address range for operation connections, you can cancel the blocking from all operation connections.
Limitations and Constraints
- Currently, the emergency policies include only the blacklist policies of VPC security groups/IAM.
- A maximum of 300 emergency policies that support block aging can be added for a single workspace you have. A maximum of 1,300 emergency policies can be added for a single workspace you have. Limits on blocked objects at a time are as follows:
- When a policy needs to be delivered to VPC, each time a maximum of 20 IP addresses can be added as blocked objects within 1 minute for each account.
- When a policy needs to be delivered to IAM, each time a maximum of 50 IAM users can be added as blocked objects for each account.
- If an IP address or IP address range or an IAM user is added to the blacklist, VPC and IAM will block requests from that IP address or user without checking whether the requests are malicious.
