Importing and Exporting Indicators
This section describes how to import and export indicators.
- Only files in .xlsx can be imported. Each time you can import a file no larger than 5 MB with a maximum of 100 records.
- A maximum of 9,999 indicator records can be exported.
Importing an Indicator
- Click
in the upper part of the page and choose Security > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
.Figure 2 Indicators
- On the Indicator page, click Import in the upper left corner above the indicator list.
- In the displayed Import dialog box, click Download Template to download a template, and fill in the downloaded template according to the requirements.
- After the indicator file is ready, click Select File in the Import dialog box, and select the Excel file you want to import.
- Click OK.
- Click
Figure 3 Workspace management page
.Figure 4 Indicators
- On the Indicators page, select the indicators you want to export and click
in the upper right corner of the list. The Export dialog box is displayed.
- In the Export dialog box, set parameters.
Table 1 Exporting indicators Parameter
Format
By default, the indicator list is exported into an Excel.
Columns
Select the indicator parameters to be exported.
- Click OK.
The system automatically downloads the Excel to your local PC.
