Importing and Exporting Vulnerabilities
Updated on 2025-01-20 GMT+08:00
This section describes how to import and export vulnerabilities.
  • Only files in .xlsx can be imported. Each time you can import a file no larger than 5 MB with a maximum of 100 records.
  • A maximum of 9,999 vulnerability records can be exported from SecMaster.
Importing Vulnerabilities
  2. Click in the upper part of the page and choose Security > SecMaster.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the navigation pane on the left, choose Risk Prevention > Vulnerabilities.
    Figure 2 Accessing the vulnerability management page
  5. On the displayed page, select a tab to go to the corresponding vulnerability management page.
    For example, to import Linux vulnerabilities, click the Linux Vulnerabilities tab.
  6. Click Import above the vulnerability list. The Import dialog box is displayed.
  7. In the Import dialog box, click Download Template to download a template, and fill in the downloaded template according to the requirements.
  8. After the vulnerability file is ready, click Select File in the Import dialog box, and select the Excel file you want to import.
  9. Click OK.
A maximum of 9,999 vulnerability records can be exported.
    Figure 3 Workspace management page
    Figure 4 Accessing the vulnerability management page
  5. On the Vulnerabilities page, click the target vulnerability tab.
    For example, if you want to export Linux vulnerabilities, click the Linux Vulnerabilities tab.
  6. Click in the upper right corner above the vulnerability list. The Export dialog box is displayed.
  7. In the Export dialog box, set vulnerability parameters.
    Table 1 Exporting vulnerabilities
    Format
    By default, the vulnerability list is exported into an Excel.
    Columns
    Select the parameters included in the exported file.
  8. Click OK.
    The system automatically downloads the Excel to your local PC.
